Engine Code Help
3rd Gear
Engine Code Help
Hello Everyone,
99 TL-P
After searching around on the Forum I realize what my engine codes mean, but I am still having trouble finding out how to fix these issues...
P1676 - FPTDR Signal Line Malfunction. I couldn't find any information anywhere to what this could be?
P1492 - Malfunction in EGR System. I found some information regarding cleaning the EGR ports on the Intake Manafold, and also information on a possible voluntary replacement of the EGR Valve from Acura. Unfortunately, my car just passed the 80k mark the other day.
I cleared the codes yesterday and they have not come back yet. Although, I would rather play this one safe. If you guys have any information that you think may help please post!
Thanks in advance,
hoclocka49
99 TL-P
Thanks in advance,
hoclocka49
not sue what the other code is for but if you are having a egr related code, you probably have a intake port cloging problem. it is very easy to fix your self if you arent afraid to take off the upper intake manifold (sounds harder than it is. takes about 1 hr to take off and clean and reinstall)
ULOOZ
The code p1676 , FPTDR line signal failure. can sometimes be caused by water getting into the connector at the ABS/TCS unit next to your washer fluid bottle. If you spray down the engine compartment as most of do.... that connector gets wet. I have found that by opening the lock on the orange connector and removing the connector from the ABS/TCS , then drying it out, then re-installing it AND securing the lock bar down again, will resolve that code. Take your time!!!!! Do it right, so as NOT to damage the connector lock bar.
HeloDown
09-08-2015 06:51 PM
