Engine Cleaning
Old Oct 20, 2005 | 08:27 AM
VITEK's Avatar
Ganji, Want some?
Engine Cleaning
Is there some type of product that i can use to clean my engine, it's really dusty and it irritates me when i look in it. Is the Engine watertight? if so could i just spray the car down?
Old Oct 20, 2005 | 08:37 AM
Da_iLLeZt_TL973's Avatar
Future JDM Whore
steam clean it mang
VITEK's Avatar
Ganji, Want some?
Originally Posted by Da_iLLeZt_TL973
steam clean it mang
is there a place to Rent a Steam cleaner?? cause i sure dont have one
Old Oct 20, 2005 | 09:03 AM
fsttyms1's Avatar
there are many good spray on degreaser/cleaners, then you just hose the engine down (as little pressure as possible)
Old Oct 20, 2005 | 09:12 AM
VITEK's Avatar
Ganji, Want some?
Should i take out my battery, or is there anything i will need to cover up? the car's completely stock so i dunno if that matters but just adding so i dont mess up anything.
Old Oct 20, 2005 | 09:15 AM
fsttyms1's Avatar
dont really need to take any thing out. just be smart with the water (meaning done go pressure washing the sensors and near the IM)
Old Oct 20, 2005 | 11:32 AM
RelentlessOne's Avatar
Graphic/Web Designer
I was also interested in this....I read something about saran-wrapping the alternator. Is this necessary?
Old Oct 20, 2005 | 11:46 AM
acutee's Avatar
To be on the safe side, as I always did, use plastic bag to cover your brake reservoir, power steering reservoir, alternator, (I never covered engine and transmission dipstick, but with the high pressure spray you may want to cover them too.), as well as sensors like fsttyms1 said.
Old Oct 20, 2005 | 12:12 PM
dvsxlt247's Avatar
99TL-p 114K
Question
Ok, where exactly are these sensors and brake reservoir located at in the engine bay??? A pic with circles around each thing would be nice!!I also wana clean my engine bay up too. So just use my hose and guide where the water is pouring onto?? Do i need to buy a specific ENGINE DEGREASER or is it just plain old degreaser??
Old Oct 20, 2005 | 01:04 PM
ou sig's Avatar
Boomer SOONER
I have done it many times - my engine with 94k miles looks good as new...anyway I have never covered anything up - you dont have too.
the best thing is Simple Green cleaner. Just spray the hell out of the engine with that and let it soak for 5-10 minutes, then I just used a regular hose and rinsed it off. If you do it at a car wash, just use low pressure and dont get too close to the engine. If your engine is real dirty, you may have to do it 2 times - but that stuff really works great.
Old Oct 20, 2005 | 04:55 PM
TL_Fo_Life's Avatar
My "P" SpAnKs YouR "S"
I just wipe down my engine bay with a rag everytime I wash my car. It stay's pretty clean.
Old Oct 20, 2005 | 06:23 PM
ndawood's Avatar
Resident Troll.
I have always been worried about cleaning my engine bay but finally did it a few weeks ago. I just covered up the battery terminals and covered the alt with a plastic bag, sprayed on some degreaser and went at it with a brush. they I just used my pressure washer to remove everything out. I used my leaf blower to dry everything up and then applied some dressing. it took about 2 hours to do everything.
Old Oct 20, 2005 | 06:42 PM
mg7726's Avatar
She said: it's GINORMOUS!
i just cover the alternator and battery, spray simple green and hose down
Old Oct 20, 2005 | 08:01 PM
415ua5's Avatar
dont you have to cover your intake as well?
Old Oct 20, 2005 | 08:04 PM
fsttyms1's Avatar
You really dont have to cover any thing. Just use common sense on where you spray the water and try not to use Super high pressure. every thing under the hood is able to get wet
Old Oct 20, 2005 | 10:40 PM
ou sig's Avatar
Boomer SOONER
ya you should try to keep water off the filter. when I had the V2 intake, I just pushed a few small towels down around the filter from the top to keep water from running down and that worked just fine.
but just like fsttyms1 said - dont use high pressure and you are fine. everything under the hood is made to get wet and be fine.
Old Oct 23, 2005 | 12:02 AM
Elegant TYPE S's Avatar
Being an Acha Bacha in
Common sense goes a long way... but then again common sense ain't so common these days.
Old Oct 23, 2005 | 12:10 AM
UglyPsycho's Avatar
S = Slow
What he said. I clean my engine bay once a week. Just spray with any cleaner and wash it down with water. Just dont over spray the alt. I also use that engine bay greasy stuff that dealers use to makes the bay look new .
oyayjoe
Jan 1, 2019 10:17 PM
01CLOwner
Oct 9, 2015 01:07 PM
sockr1
Oct 1, 2015 01:31 AM
jaynatlanta
5G TLX Problems & Fixes
Sep 15, 2015 11:08 AM
Sep 14, 2015 10:09 PM
