eletrical problem
Old May 18, 2005 | 09:21 AM
SLAMMED_WDP_TLS's Avatar
eletrical problem
I neve had an electrical problem until I put in the new crank pulley. Anyone had such a problem avter installing pulley, if so how do I fix it. thanks
Old May 18, 2005 | 09:30 AM
Bxscig's Avatar
What is the electrical problem?
Old May 18, 2005 | 10:12 AM
phipark's Avatar
Not Asian
It is known that replacing the pulley with a smaller or underdrive pulley will decrease voltage. The UR crank pulley isn't supposed to drop the voltage below 12v with everything running, unless you have a high-wattage stereo system.
Old May 18, 2005 | 11:05 AM
kRaZy_TL's Avatar
:heart: Boosted Carz
Get the UR 12v crank pulley. Thats what I have. No problems at all even w/ my 800w system. What kind of electrical problem are you having?
Old May 18, 2005 | 11:27 AM
NSXNEXT's Avatar
I've had my pulleys in for 25,000+miles and no problems whatsoever.
Old May 18, 2005 | 01:25 PM
well, after I install the crank pulley in Feb everything was fine for 2 months. Then my car started to die on me. I thought it was nothing. Then It happened more and more. So I switch the battery out. The battery I got was not cheap but like mediocre. After I installed it it woulndt start. I thought it was my alternator or my starter but its neither. My body shiop guy acutally came down with his brother to takea look at my car. <--- nice service for a body shop guy but he also does mechanic work. WE jumped the car and he said its the battery that its not strong enough to start the car. I never have any battery or electrical problems before the crank puelley installation. Man I was freaking out when this happen because when I go start the car, the car ticks and and my windows start to roll down by itself. Felt like my car was possesed. My guy siggext get a new OPTIMA battery so I am gonna try that and hopefully everything will be ok. KEEPING MY FINGERS CROSSED!!! I only got my car back for a week after the conversion and it jsut been sitting there looking pretty dman I WANNA DRIVE IT!!!
Old May 18, 2005 | 01:59 PM
NSXNEXT's Avatar
Get a volt meter and test out the battery.
Test 1: Car off
Test 2: Car in key positon II
Test 3: While cranking engine
Test 4: When engine is running
Old May 18, 2005 | 04:09 PM
I got the red optima and the car workd fine now. *knock on wood* but so far so good.
Old May 18, 2005 | 04:30 PM
Bxscig's Avatar
Yeah I was going to suggest what nsxnext said. I think the red top has more cranking power then the yellow top. Is that correct? Enjoy the new car!!
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
