Electrical Issue.
Old Dec 19, 2013 | 03:03 PM
Curious3GTL's Avatar
Electrical Issue.
I have done multiple searches and can't seem to find anyone with the same issues. My turn signal doesn't work. Here's what happens:
You turn the signal on and it just blinks once or twice and stops. Sometimes it blinks more or sometimes it blinks less. The way you get it to start blinking again is the following:
1) Leave the lever pushed to the right or left. Eventually it comes back on.
2) Push the flashers on and off.
3) Turn the signal on and off.
For whatever reason it doesn't work at all when the car is "on" vs idling.
P.S. Yes I know my name says 3G but I made this account to originally get some information on a 3G. The TL that's having the blinker problem is the 2000.
P.S.S I checked the bulbs and they all seem to be fine.
Old Dec 19, 2013 | 05:34 PM
I don't know if it helps but I took pictures of under the wheel.
Old Dec 19, 2013 | 08:17 PM
01tl4tl's Avatar
I suspect the turn signal relay, located under hood in one of the boxes
they are all marked
ok to swap another relay of same color and test
the battery cable connections are clean? battery tested?
winter puts the hurt on old ones,,old being 3 years
Old Dec 20, 2013 | 12:19 PM
03blackbeast's Avatar
Actually the Flasher relay is under the dash on the drivers side. I'ts basically the back side of the fuse box on the drivers side. You'll have to crawl under there. It's the black relay to the right farthest down towards you. There's 2 plastic clips that hold it in you'll have to release to get it out. Pretty easy swap. They sell them at autozone for like $10
Old Dec 20, 2013 | 12:56 PM
fsttyms1's Avatar
^ agree. Id start with the turn signal flasher relay.
Old Dec 20, 2013 | 04:23 PM
they are all marked
Thank you for your response. I assume it is not the battery for two reasons:
1) The emergency flashers seem to work much better (but not perfect)
2) The car has no trouble starting or with any other electronics.
That's great! Thanks so much for that info.
Thank you as well.
For $10 it's worth a try.
Old Dec 20, 2013 | 04:38 PM
I went out and took a picture. I am assuming you all mean the black box?
Old Dec 20, 2013 | 05:55 PM
01tl4tl's Avatar
likely
the local parts store can help you with lookup - to verify
Old Dec 20, 2013 | 07:22 PM
Thanks guys!! It worked!! I have attached an imagine of the comparison parts. The replacement part is a lot bigger but it now works like a charm. The part was $12.99 at O'Relly's.
The clicking sound is also different now. It's minor but in case anyone is interested I figured I would attached a video as my way of saying thanks.
http://www.youtube.com/watch?v=gWAPI...ature=youtu.be
Old Dec 21, 2013 | 03:57 PM
3.2TLc's Avatar
Good pics, glad to hear that all's well, thanks for following up.
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
joflewbyu2
Oct 8, 2015 11:16 AM
MikeJM310
Sep 24, 2015 07:24 PM
