e brake
Old May 16, 2004 | 12:59 AM
medasuRiderz's Avatar
e brake
hello, i have a 2000 and i sometimes forget to take off my e brake and drive with it. i sometimes have driven for 5 minutes before i noticed. is there something wrong with my e brake? it doesnt seem to hold like my other cars in the past. has any1 else noticed this?
Old May 16, 2004 | 01:01 AM
`ill*tl's Avatar
When you drive with your E-Brake on..you're wearing down your pads x100. That's why it doesn't hold..
Old May 16, 2004 | 02:49 AM
well, ever since i got the car it never resisted driving with the e brake on. and the rest of my cars wouldnt even let me drive with the e brake on at all. so i need to replace my rear pads then?
Old May 16, 2004 | 10:46 AM
etxxz's Avatar
@ slide or die @
Most unlikely its your pads, maibe you dont kik that e-brake low enough so it doesnt cause much resistance. hell, I hit my e-brake at 70mph with threadless rubber, and trust me, it does hold up.
Old May 16, 2004 | 05:05 PM
fsttyms1's Avatar
your pads are probably shot, the rotors may be inside too. it should hold the tires if its all the way depressed. i know mine does cough cough DONUTS cough cough...
Old May 16, 2004 | 05:13 PM
njtls's Avatar
jsut put the ebrak down and put the car in drive and see if it moves...
Old May 17, 2004 | 03:02 PM
john32's Avatar
i thought the e brake was a drum brake
Old May 17, 2004 | 03:19 PM
fsttyms1's Avatar
it is. its in side the inner hub part of the rear rotor
Old May 17, 2004 | 03:21 PM
poohlikeshunny's Avatar
Money is funny.
drums?
Hey there...still kinda new to the whole mod scene....what is the difference between drum brakes and disc brakes?
Old May 17, 2004 | 05:27 PM
medic's Avatar
it's not a mod it's the way the brakes are designed. I'm sure you can switch from drums to discs, but not sure what all that would involve.
Disc brakes are disc that the pads squeeze from both sides to stop the car (think of the brakes on a bicycle)
Drum brakes are like a big dounut. The shoes are located on the inside of a rotating cylinder. When you press on teh brakes, the shoes push out from the inside of the cylinder to stop the car.
That may not make much sense to you, so let the experts explain it: http://www.edmunds.com/ownership/tec...7/article.html
Old May 17, 2004 | 07:25 PM
etxxz's Avatar
@ slide or die @
yup, on our cars, the drums lock the back weels only...thats how you pull 180s, too bad we cant go that.
Old May 17, 2004 | 07:36 PM
crazym0nkey's Avatar
Actually you can pull 180s Theres that video of a TL on some roof garage doing a 180......it was a SSM TL ...im sure if you search you can find the link and video
Old May 26, 2004 | 08:23 PM
etxxz's Avatar
@ slide or die @
i know we can...i ment to say too bad we cant go over it...ive done 180s before on a 2 way street.
GWEEDOspeedo
Jan 15, 2016 10:39 PM
lanechanger
Oct 13, 2015 10:56 AM
rockyboy
Oct 2, 2015 10:45 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
2ManyHobbies
Sep 24, 2015 09:23 PM
