DW-1 vs. Z-1
2003 TL-p
dw-1 is thinner, and part synthetic. z1 has been discontinued. dw-1 is backwards compatible with z1.
i currently have dw-1 in my tranny, and iv noticed much improved cold weather shifting, overall quicker and smoother shifting, along with cooler temps under the hood. i have only positive things to say about dw-1.
although i would not use dw-1 in a tranny that is already slipping, as it will most likely get worse after some time.
if its already slipping, there is nothing oil would do to help~
you may still find a few quarts of z1 on an import parts store shelf
otherwise honda/acura dealers are sold out and carry the new stuff DW-1
Its a buck or 2 cheaper at honda for the exact same stuff
I have a 92 Accord EX with 235k. (Peeking out behind the TL in my avatar). The trans had a slight shudder when going into second.
Did a fluid change a few weeks ago and the shudder is gone.
In my opinion whatever Honda spent to reengineer their trans fluid was worth every penny (especially in warranty repairs!).
Hi,
Yes I put in just a touch under 3 qts DW-1.
I was going to cycle through 9 qts in 3 more changes if there wasn't any drop in performance. That one change made the trans shift more precisely and the shudder is gone. I will do the remaining changes to evacuate the remaining fluid.
Keep you posted.
My 99 TL shifts better than new with DW-1 - I bet/hope everyone says the same.
Keep you posted.
vpasla1
09-17-2016 07:24 PM
DiamondJoeQuimby
09-10-2015 11:40 AM
