Dual Stage Shock Sensor Problem
My Crime Stopper Dual Stage Shock Sensor goes off when a car with a exhaust comes by or something that makes the floor vibrate. I can't go anywhere public and leave the car with the sensor engaged. I lowered the sensitivity to the lowest setting and the sensor still goes off.
The funny this is when I shake the car the alarm doesn't go off.
Let me know if anyone had this problem and how they fixed it.
that's what happens when i'm in a parking garage. i start my car and the surrounding cars with sensors have their alarms set off. and i just have comptech exhausts and removed my resonator!
it's pretty funny when people around look to make sure i didn't bump their car!
peter.
peter.
If I remove the pre-warn trigger it would go off soon. I thought the pre-warn trigger gave a warner then if it kept moving they it would go off...
I dont understand y it doesnt go off when I shake the car...
the one i have has both a pre-warn and main trigger light. The pre-warn is more sensitive, but if it goes "on" frequently enough (even before the main trigger is ever "lit"), it causes the alarm to go off.
You may have a different kind than i do and they are all different.
and the reason it doesn't go off when you shake the car is because it's not a "shock". I have a combo shock/motion sensor that I will eventually hook up when I have time which would take care of the movement part of the equation.
mada51589
Jan 9, 2025 04:40 PM
cycdaniel
Dec 17, 2019 10:58 AM
Sep 17, 2015 09:01 PM
