Droping stearing wheel for dash removal?
I have removed my dash a couple of times. Each time its hard to squeez it out from behind the steering wheel. I have a small crack from squeezing it through. Nothing you can see but I'd like to keep it that way. It would help if the steering wheel was out of the way. Anyone have any experience with this? Thanks in advance
well, from my experience, i just unscrewed the 3 screws on the underside of the steering column cover and pulled the top part off..this would give you a little more space to work with but i would say it's still a bitch taking out the dash
Originally Posted by REV-01
2-12mm and 2-14mm will drop the whole steering column, will give you even more room than just removing the covers
if you look underneat the dash on the driver side you will see two 12 mm bolt and two 14 mm nut holding the whole steering column, remove them and you will have alot more room to work with
Thanks for all the good info
JP
mada51589
Jan 9, 2025 04:40 PM
cycdaniel
Dec 17, 2019 10:58 AM
merc009
Oct 3, 2015 12:59 AM
detailersdomain
Wash & Wax
Sep 3, 2015 10:56 PM
