drl's stop working
Old Oct 2, 2009 | 03:35 PM
kdawg8526's Avatar
13.2@106mph G37 RWD Sedan
drl's stop working
my drl's stopped working on my car and the drl light is on and when i high beam the passenger side doesnt turn on
i changed the bulb but no luck.. i checked the fuses and checked the 3 lighting relays under the hood they look fine
can anybody tell me if theres something else i should check on maybe another relay somewhere... i dont want to pay 3 to 4 hundred dollars to the dealership...
i tried searching but couldnt find anything that helps
Old Oct 2, 2009 | 03:55 PM
acutee's Avatar
We don't have drl, unless you modified.
Old Oct 2, 2009 | 03:56 PM
ANC297's Avatar
Bonki' Ehrite!
If my knowledge serves me right, we do not have drl's, only fog lights that without modification cannot be on without the use of the headlights. As per the problem with your high beams, IDK.
Old Oct 2, 2009 | 04:23 PM
hANDYcaptd's Avatar
It's the Halladay season!
He's from lol They has teh DRL...
Maybe one of the Canada guys can chime in and help
Old Oct 2, 2009 | 04:40 PM
ANC297's Avatar
Bonki' Ehrite!
Oh, I did not know that....I guess u learn something new errday. l0l
In the drivers side fuse panel, what is the day time light, or daylight fuse for? Mine is missing, so last night I tried to place one in and it would not stay in place. The slot was too loose for the fuse itself. Any ideas?
Old Oct 2, 2009 | 05:08 PM
dsickles's Avatar
there is probably no wiring in there for the fuse to connect to, probably a different harness for Canadian vs non-Canadian
Old Oct 2, 2009 | 05:23 PM
t0o's Avatar
t0o
i'd like to know this aswell, my DRL is on since I've had it, my old accord had that problem also. I live in Canada
Old Oct 2, 2009 | 05:45 PM
ANC297's Avatar
Bonki' Ehrite!
Is the place for the fuse for the DRL's? What else could be day time lights?
Old Oct 2, 2009 | 06:08 PM
dsickles's Avatar
not sure what your asking, maybe im missing something
Old Oct 2, 2009 | 06:34 PM
ANC297's Avatar
Bonki' Ehrite!
It is an american model...In the drivers side fuse panel, like 4 or 5 fuses from the bottom is a fuse for "day time lights" or something like that, i forgot the exact wording. However, there was no fuse in the slot. I went to put one in there yesterday but it would not grab the fuse, almost like the slot was too big or something.
My questions are, why would the fuse not stay in its slot? And what are the day time lights, or whatever they are called.
Old Oct 2, 2009 | 06:51 PM
dsickles's Avatar
first off day time running lights or drls for short are a safety feature required for all Canadian cars, it essentially provides the high beams with low voltage so that during the day the car is more visible to other drivers. when you turn your regular lights on the drls turn off.
since this feature is not required by the US it is not present on US spec tls. in order to make this feature work you would need relays and wiring which your car does NOT have, this is why there is no wiring to the fuse box for the drls on your car.
it is an empty spot on the fuse panel, no wiring goes there, and it wont make your car have drls if you put a fuse there
Old Oct 2, 2009 | 07:23 PM
ANC297's Avatar
Bonki' Ehrite!
Okay, thanks.
Nd, about the bold....If that were the case, I would be putting fuses in everywhere for all kinds of features. l0l
Old Oct 3, 2009 | 01:52 AM
kdawg8526's Avatar
any canadian drivers help me out here for the daytime running light problem ?? i really need to get this fixed because i have a inspection in about 2 weeks
Old Oct 3, 2009 | 09:39 AM
TLin401's Avatar
'13 Hyundai Sonata
You might have a short going to the bulb. Take a meter and see if you are getting power to all of the locations (bulb, relay, fuse) also check to see if they are dead.
Old Oct 4, 2009 | 02:02 AM
kdawg8526's Avatar
thanks mann... is there a relay for the drls ?
Old Oct 4, 2009 | 09:13 AM
TLin401's Avatar
'13 Hyundai Sonata
Yes I would check under the hood, the driver's side fuse box. Then try looking on the passenger's side on the right. I found about 6 relays on the right one time when I was fixing my fog lights.
Old Oct 4, 2009 | 11:25 AM
kdawg8526's Avatar
how do i know if the relay is gone bad
Old Oct 4, 2009 | 11:29 AM
TLin401's Avatar
'13 Hyundai Sonata
If you have a meter and turn it to the OHMz if it reads 1 then it is dead.
Old Oct 4, 2009 | 11:54 AM
kdawg8526's Avatar
you cant tell just by looking at it? like does it get corroded?
Old Oct 4, 2009 | 11:57 AM
TLin401's Avatar
'13 Hyundai Sonata
Now that you mention it, is the connector corroded? The one that goes into the DRL.
Also try removing a relay and switch the DRL relay with that relay to see if it is good.
The ground on the relay may be bad which causes one bulb to go out.
Old Oct 4, 2009 | 12:22 PM
kdawg8526's Avatar
i dont know where the relay is though... would it be under the driver side steering?? where the srs is
Old Oct 4, 2009 | 12:27 PM
TLin401's Avatar
'13 Hyundai Sonata
If you have a manual check it because it should tell you where it is. I checked mine and that is how I found a bunch of relays in one area. Check in the passenger's side foot area next to where the door is. Pull the panel off and there should be relays up there. You are going to need a flashlight.
Then I needed a 14mm socket to remove the bolt holding the relay panel in place.
Then I used my manual to figure out which relay is which.
Old Oct 4, 2009 | 01:39 PM
kdawg8526's Avatar
kool thanks man ill update later at night let u know wat happened
Old Oct 5, 2009 | 12:46 AM
kdawg8526's Avatar
ok so i tried checking all the fuses for drl and i only found 2 lighting relays under the hood and i changed them but no luck still... i changed the bulb too still didnt work... now i dont know what to do... thinking about paying my mechanic to fix it
Old Oct 5, 2009 | 07:25 AM
juanclopez2786's Avatar
have you taken off the bumper recently for anything? one time i had a problem with a newer accord where the p/s light didnt work and it was because i installed hid's in the fogs and i mounted the ballast with a ground wire right underneath that light.
Old Oct 5, 2009 | 09:37 AM
TLin401's Avatar
'13 Hyundai Sonata
That makes sense now because like I said previously this could be a ground issue.
Old Oct 5, 2009 | 12:09 PM
kdawg8526's Avatar
i did recently take off the bumper to install the hids but the drls havent been working for a year now.. but i didnt really bother tryin to fix it cus i like driving round with hids on even during the day
but now i have no choice but to fix it cus of the inspection
Old Oct 5, 2009 | 12:15 PM
kdawg8526's Avatar
i just talked to my mechanic and he told me it probably the drl module.. does anybody know if i can change that myself or should i just let him fix it?
and where might the location be for this module?
Old Oct 5, 2009 | 07:32 PM
Edward'TLS's Avatar
6G TLX-S
The Canadian DRL/high-beam circuit is extremely complex. Unlike the US high-beam circuit which only uses the mechanical combination-light-switch for control, the DRL/H-B circuit is built around the DRL control unit.
The DRL control unit supplies power directly and separately to each of the high beam bulbs, the other leads of the two high beam bulbs are connected together and going through the high-beam-cut relay and combination-light-switch before going to GROUND. This way the control unit can supply reduced power for DRL operation and full power for high-beam operation.
So if the driver-side high beam works, it means that all fuses and relays are working properly. Provided that the passenger-side high-beam bulb is good, it is very likely that the problem lies in the DRL unit which is not supplying power to the passenger-side bulb, but is supplying power to the driver-side bulb.
The DRL unit is located underneath the driver-side dashboard. If you lie down on the driver-side floor and look up, you'll be able to see it hanging down underneath the steering column and towards the right hand side. I vaguely remember that the small black module is labeled with something like DRL letterings.
Old Oct 5, 2009 | 07:34 PM
TLin401's Avatar
'13 Hyundai Sonata
Also if you replace it, you should be able to just unplug it I believe.
I could be wrong.
Old Oct 5, 2009 | 08:21 PM
JoeTL99's Avatar
The drl control module stops working usually because the solder joints go bad. I fixed mine by re-soldering the joints. This link was very helpful http://www.nyx.net/~smanley/hondadrlfix/
Old Oct 6, 2009 | 12:14 AM
kdawg8526's Avatar
hey thanks... your like 10 mins away from me you should come out to one of our meets sometime check out the regional forum western canada
Old Oct 6, 2009 | 02:18 AM
Edward'TLS's Avatar
6G TLX-S
I used to go to meets when I was at your age. But now I'm too old for those.
Old Oct 6, 2009 | 10:39 AM
TLin401's Avatar
'13 Hyundai Sonata
You are never too old for meets. IMO
Old Oct 6, 2009 | 10:56 AM
t0o's Avatar
t0o
age doesn't matter unless you're a cheese!
Old Oct 6, 2009 | 11:00 AM
kdawg8526's Avatar
yeah man you should come by and show us your ride
Old Oct 7, 2009 | 02:26 AM
Edward'TLS's Avatar
6G TLX-S
Back 15 years ago in Vancouver, aftermarket tuner shops opened up like wild flowers, and people all rushed in to mod their cars and trucks. Street racings became the norm. Unfortunately, many kids over-estimated their abilities and thus fatal car accidents had become news headlines almost once every few days.
In order to curb street racing fatalities, local police decided to monitor car meets for illegal car mods, and also took pictures of all participants for records. As a result, most of us had since stopped going to car meets altogether.
Even thought we have done no illegal deeds, but we don't particular enjoy having someone opening a file for us.
Old Oct 7, 2009 | 02:51 AM
03aspec's Avatar
lol this thread makes no sense..
dude, i had the same problem on my old 00.. take a look at the drl module underneath the steering column, its a grey little box. the problem that i had, was that two of the soldered connections inside had come loose somehow, i re-soldered and they started working again. hope this helps.
Old Oct 7, 2009 | 05:06 AM
kdawg8526's Avatar
thanks dude im gonna get my mechanic to repair it cus acura said its 200 dollars for a new module
i think ive seen your car on cardomain also... looks very nice
Old Oct 8, 2009 | 07:21 AM
03aspec's Avatar
my car is not nice, it is poop.
