DRL, how do I wire this up?
Old May 15, 2012 | 09:59 PM
02 TL's Avatar
I want to make the light bulb under the turn signal (in my pic it's orange) work as a Daytime Running Headlight using an LED bulb. How can I wire this up? This is stopping me from finishing my quad retrofit set up . Help me out here A-Ziners.
Last edited by 02 TL; May 15, 2012 at 10:03 PM. Reason: Change words to make more sense
Old May 15, 2012 | 10:31 PM
dreem1er's Avatar
deal with it
you should be able to wire it to a fuse with an add a circuit, just got to find one thats on at all times.
you could wire it using the foglight diy and have drl fogs and those light, or you can hot wire to the battery and add a on/off switch inside somewhere
Old May 15, 2012 | 10:32 PM
victus1's Avatar
Very easy. It's best to drive those LEDs with an automotive relay that is driven by the ignition wire which is +12V when the car is running.
Just tap into the IGN wire which is 12V when the engine is running. It is under the driver side dash, on the upper left. You will see a bunch of plug in's. I forgot which one it is. Use your test light or volt meter to see which one is 12V when the engine is running.
Then use this IGN wire as a "turn on" signal into your relay. The "output" pin of the relay goes to both your LEDs. The only other connections are +12V battery and ground to your relay.
LogicWavelength
3G TL Photograph Gallery
33
Nov 1, 2015 09:38 AM
MilanoRedDashR
Oct 8, 2015 10:30 AM
SUPRMN84
Oct 7, 2015 09:46 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
greeneyes.hypnotize
Sep 27, 2015 02:47 PM
