DRL Disabling
Old Apr 5, 2004 | 02:30 AM
chewi's Avatar
DRL Disabling
Old Apr 5, 2004 | 02:31 AM
chewi's Avatar
to canadian owners...
how do u disable the Day time running lights....
help is appreciated...
thanks
Old Apr 5, 2004 | 07:29 AM
sc354's Avatar
thanks
My guess is you could remove the fuse...not sure though if the DRL's are attached to the same fuse for that of the low beams HID's...
BTW this mod would definitely be illegal since all cars above the year 1993, are mandatory to have DRL's...honestly if you want to remove your DRL's, look into converting them to HID also. That way, they are all white even during the day. Some members on this forum are also looking into this mod...
be prepared to pay for it though, it will run you about 400-500 bux.
Old Apr 5, 2004 | 08:00 AM
hzm82's Avatar
You can't put HID aftermarket into the highbeam if you have DRL. DRL is using lower wattage then lower beam and there won't be enough power to light a HID system. Basically the same thing as not having DRL, so it's illegal in cananda.
LogicWavelength
3G TL Photograph Gallery
33
Nov 1, 2015 09:38 AM
joflewbyu2
Oct 8, 2015 11:16 AM
greeneyes.hypnotize
Sep 27, 2015 02:47 PM
spiel08
Sep 7, 2015 08:19 PM
Fadij
Sep 2, 2015 08:31 PM
