Drivers Side Front Window Switch or Motor?
Old Oct 25, 2013 | 05:14 PM
IHaveNoIdea2012's Avatar
Drivers side front window does not work. How can I find out if it is the switch or the motor that is not working. When I press the window button nothing happens - I dont hear the motor trying to turn. All other windows work find. Thank You in advance.
Old Oct 25, 2013 | 06:44 PM
3.2TLc's Avatar
If all the other windows work normally, ya need to pull the driver's door interior panel off to actually see what's wrong.
Check the connectors and then test for power at the window motor while activating the switch.
Old Oct 27, 2013 | 06:01 PM
Thanks I will try that first. Also my SRS light is on - I saw a link that showed how to reset it. But when I pulled the fuse panel I could not find a yellow connector to pull off in order to place the paper clip into. Which connector is it? Thanks in advance.
Old Oct 27, 2013 | 06:18 PM
3.2TLc's Avatar
It's up under the driver's side dash. Look again, as ya have to be a contortionist to get at it.
Old Oct 27, 2013 | 06:52 PM
Wow - found it - your right - dont think my back will ever be the same. Had a hard time putting the paper clip but after 10 tries I got it - thanks again for your help. I have a good DIY link to replace a 2nd generation window regulator - dont know where the DIY links are or how to find them. If you can - try to post this link - very detailed:
Anyway thanks again
Old Oct 28, 2013 | 07:05 AM
3.2TLc's Avatar
Sometimes it takes a bit of persistence along with some patience for DIY 's !!!
But the end result of having done the job yourself and saving a shitload of money makes it all worth the while.
Old Oct 28, 2013 | 04:29 PM
TLer trash's Avatar
There are a couple things you can try to narrow down your diagnosis before you remove the door panel. First, turn on the dome light, and watch it closely while you try the switch. If you get a slight dimming in both directions, the switch is probably good. You can also test the switch by pulling the small panel that it sits in and accessing the connector underneath it. Beyond that, you should check it at the motor as 3.2TLc mentioned to rule out any broken wires in the door hinge area.
Old Nov 2, 2013 | 03:50 PM
Yup the dome light dims while pressing the window switch. Any ideas were to find a regulator with a motor. I found this link - but any other suggestion on where to purchase one? Thanks in advance. http://www.autopartswarehouse.com/se...dow+Regulators)
Old Nov 2, 2013 | 03:52 PM
Old Nov 2, 2013 | 05:01 PM
3.2TLc's Avatar
Try Rockauto .
peti1212
ILX
22
Jan 5, 2022 05:14 PM
TLDude876
Dec 28, 2016 03:18 PM
nanos
Nov 12, 2015 08:41 PM
Ny1718
Sep 11, 2015 09:21 AM
08 NBP TL
Sep 8, 2015 08:49 PM
