Alignment question
Old Nov 3, 2013 | 01:19 AM
Bricktop's Avatar
Alignment question
I'm planning to replace my front struts, (removing strut assembly with out disturbing control arms/tie rods/radius rod). Is it necessary to get an wheel alignment after removing and installing the struts?
Old Nov 3, 2013 | 01:36 AM
Karanx7's Avatar
Unregistered Member
Not really
Old Nov 3, 2013 | 03:17 AM
HairyMonkey019's Avatar
So you're worried about the alignment changing, if you put a stock height car to stock height???
jk
It should be fine. If you're worried check your tires every oil change or 1.5k miles.
Old Nov 3, 2013 | 04:45 PM
Bricktop's Avatar
Thanks, good to know.
I replaced upper/lower control arms, outer tie rods and ball joints. And had the alignment done.
It would have been a perfect opportunity change out the struts while i had these parts out the car, but I didn't have the coin at the time.
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
juanrl
Sep 29, 2015 03:25 AM
navtool.com
Sep 25, 2015 05:15 PM
