Dripping
Dripping
Here is the problem guys, when I take my car through the car wash water seems to leak through the cowl and to behind my dash. Is there a common problem with the second gen tl's or is this something serious that I need to get checked out? It is very annoying but it only happens when I run it through the car wash. Thanks in advance.
i did but the hole to be a bit too small for my hand. i dont have large hands either. but ill try and disassemble the cowl, hope i dont break anything, and check for what might be causing the leak.
you will have to remove the windshield wiper arms, then remove the plastic guard. clean out every thing trapped under there (the intake side is on the passenger side) look for drain holes and stuff make sure they are free and clear.
did that today finally and there was nothing in there. was spotless in there. dont know what to do next. really dont want water leaking into my car. might cause future electrical problems. lmk what you guys think it might be
Originally Posted by fsttyms1
then i would look into the moonroof drain hoses. Is it the passenger side or drivers side.
Originally Posted by philly fresh
passenger side. i just assumed it was coming in from the firewall. but where would i start to look as far as those holes being clogged up and where do they drain to.
Open the sun roof and look at the channel on the hood side. Mine were clogged, but you could not tell just by looking at it. On that SUV, the water from the drain holes would run down the A-pillars, so if it was clogged, it would wet the floor of the passenger side. I ran a 5 foot length of 18-gauge wire down the hole all the way down to where it ran to the bottom, and moved it around for a bit. Problem solved.
Do you happen to have your AC running when this happens?
yes actually i do most of the times. there were a few times that it did not leak one bit but i can not for the life of me remember if i had the a/c on or not. if i do have it on then what do you think it could be.
IBankMouse
06-13-2020 12:53 PM
