dremeled fog area???
Old 09-11-2005 | 02:47 AM
z3Ro's Avatar
Mr. 2tone
does any have their fog area dremeled out? kuz im planning on doing mine...but im scared...1 good reason is that itll just let the wind into that compartment rite where the filter is for the cai....but in doing so...wouldnt that put force on the plastic cover for the wheel weld...wouldnt that force just rip it off?? n what bout rocks...what if a few lil pebbles shot into that area...would they get the engine??
Old 09-11-2005 | 07:39 AM
keiser sozae's Avatar
2002 ABP TL Type S
your airfilter should stop any "lil pebbles" from damaging your engine.
Old 09-11-2005 | 10:06 AM
bkzjimmy's Avatar
NiGhT rIdEr
after opening the hole u shorld put some mesh in there.....
it would stop most dirt and still let air in and it gives it a nice look
Old 09-11-2005 | 11:50 AM
RelentlessOne's Avatar
Graphic/Web Designer
I dremeled out both corner foglight pockets and wrapped mesh around from the inside, and then used silicon to hold it there. It's holding up great and havn't encountered any problems.
Old 09-11-2005 | 02:20 PM
z3Ro's Avatar
Mr. 2tone
that was my 1st idea but i have my fogs in the lower grille...so if i mesh my side pockets im gona mesh my lower grille...but if i do that i cant adjust my foglites...
Old 09-11-2005 | 03:11 PM
ou sig's Avatar
Boomer SOONER
it shouldnt be a problem if you put some mesh on it. Though if you drive alot in the rain, water will get all over the filter (shouldnt hurt anything) but you will have to re-oil the filter alot more often because the oil will drip off when the filter dries.
Old 09-11-2005 | 03:21 PM
z3Ro's Avatar
Mr. 2tone
what do u mean by re-oil...any1 know bout the rock question yet?...if the filter blocks the rocks on that side...what bout the other...thats where all the pulleys n belts r
Old 09-11-2005 | 04:00 PM
ou sig's Avatar
Boomer SOONER
all CAI filters are the K&N type filter that have the reddish oil on them to help with the filtering. if you have that plastic off, the water will spray on the filter and make the oil run off. It will obviously be best if you put some mesh over the hole - that would block the larger rocks so you will be fine after that.
Old 09-11-2005 | 06:49 PM
NSXNEXT's Avatar
Here's mine. Matches my Mugen grill.
Old 09-11-2005 | 10:55 PM
z3Ro's Avatar
Mr. 2tone
yea...mayb ill do that...so bout the wind question...do u drive fast?...
quanaman
01-09-2023 07:33 PM
lanechanger
10-13-2015 10:56 AM
Avenger411
10-11-2015 03:53 PM
rockyboy
09-29-2015 12:05 AM
rhdune16
09-28-2015 11:31 AM
Quick Reply: dremeled fog area???
