Double Din Kit for Aftermarket Head Unit Question
Which kit looks closest to our factory dash.
I heard Metra makes one... could someone supply the Metra Model Number or some other options?
Is there a paint color that we can buy to match our dash?
If so, pleas tell us where to get it and the color or a place that can match it.
Originally Posted by NYZGREATST
there is no double din kit. there is only a single din kit made my metra. if you want double din, it has to be custom fabricated.
only single din.
but if you go that route get teh metra kit and sand it smooth to match, start with 220, then 400 wet then go to 600 wet. then 800 to 1000 wet. the finish will be really close. sloser than paint. the factory dash has a small flake in it, so no paint will truly match
A double din will bolt up to the factory brackets. I just had an Eclipse 7301 double din in my 2000 TL. But, you will have to make a trim ring to go around it. That is really where the problem lies. Making something that looks factory and fits factory.
i got double din in my car, i used the factory brackets, what i did is used a factory mounting bracket from a suzuki grand vitara, screw the decks into the other set of holes that our acura bracket don't use. then put the whole thing in and used a abs plastic to build the trim, because the grand vitara brackets has a 90 bend at the end with 4 holes at the corner, the abs plastic can be screw on or glue on, and sand to factory smooth, i build another bracket sandwich between the deck and grand vitara bracket so it extend up from the deck and hold the factory notepad assembly, i did not sand mine because i got a carbon fiber dash kit, this is probably best way to do it because it used factory holes.
i will try find some pics
i used to have day pics, i couldn't find it in my computer anymore, i used to have it at acurainspired.com but i delete them already, i found 2 dark pic in my computer, here you go:
Oh... I can see it now... That does look cool... But, for those of us that want to stay with the factory look...
I'm probably going to get a single din DVD player... Then I might get another single din digital EQ.
So, will I have to get a custom face/dash done while I use the factory brackets? If so, what is the closest/easiest/cheapest way to achieve this goal?
I really don't want to sand shit... I'd rather paint it or use a material that's right on the money. I saw an acrylic that looked close.
That's a very nice setup, but I'm looking for something more factory looking.
I'm trying to figure out what it would look like if there was a pocket in the top din or what it would look like if I put the new head unit in the middle.
Ok, check it out...
I need my head unit to sit lower than the top din because I have a factory navi screen that the hu screen will overlap.
What if I bought the metra kit... took it somewhere and asked them to customize me one that has the pocket on the top...
Is this the way to go? What material should be used? What are my options?
There has to be something out there to color match...
TLStar
Originally Posted by Luded
REV-01 why does your clock say "CHECK" or something like that on it, and how come the display for the clock is back-lit in green ??
I dont think painting the dashboard would be the best idea. Cracking, etc. Your best bet would probably be just to swap everything out for the black interior but that's gonna run you a pretty penny.
Originally Posted by DUB_TL
also has anyone tried to paint the dashboard themselves??..mine is tan and I want to switch to black any suggestions
Hmm...Is that right??
Originally Posted by fsttyms1
you would have to geta upholstery die type paint, you would be better off finding a black one in the junk yard
Yeeeehaw!
Originally Posted by AustNMike
just FYI, you shouldn't dye or paint airbag covers (on steering wheel and dashboard).....if they've been pianted and deploy in an accident, it will send shards of paint thru the occupants face and eyes....ouch!!!
Soul_Deamon
11-13-2018 04:44 PM
handsom-hustla
11-13-2015 05:04 PM
trinikidcl
09-04-2015 12:56 AM
