Door Trim Cracking!! HELP!
99TL-p 114K
Some of you might of had this problem already, but my 99TL's Door Moldings are cracking. The thick black pieces inbetween both doors on both sides of the car is starting to crack and it just keeps getting worse and worse as time goes by. As you can see in the following pics, You'll obviously see what i mean. Has this happened to anyone else already and if so, Can it be fixed or replaced or what? How can i fix that so that it looks nice again?
Driver Side
Passenger Side
NEED HELP! ????
Driver Side
Passenger Side
NEED HELP! ????
05 C230K & 09 135i 6MT
That's an age thing that all of our TLs have or will have, unfortunately. My TL is an 02 and does not have this yet but it is only just a matter of time, I'm sure.
TL = Tranny Lubrication
that's the B-Pillar they same to shed the tape off - you have a couple of options - replace them $40-50 each (you need 4 total) or take these off and get them painted or lastly replace them with carbon ones....
Parts that you would need
http://www.acuraparts247.com/sunnyside/jsp/home.jsp:
Front door
ITem# 006 Part#/Name 67326-S0K-A00ZA TAPE, R. FR. DOOR (UPPER) (OUTER)
( BLACK ) 1 1999 Acura TL $28.65
Item# 011 Part#/Name 67366-S0K-A00ZA TAPE, L. FR. DOOR (UPPER) (OUTER)
Rear Door
Item# 006 Part#/Name 67826-S0K-A00ZA TAPE, R. RR. DOOR (UPPER) (OUTER)
( BLACK ) 1 1999 Acura TL $22.05
Item# 010 Part#/Name 67866-S0K-A00ZA TAPE, L. RR. DOOR (UPPER) (OUTER)
These are also the small strips that run over the windows. Damn things are taped you we would all rather they were painted if possible.
Following is the B-Post piece, located under Molding:
Item# 004 Part#/Name 72430-S0K-A01 GARNISH, R. FR. 1 1999 Acura TL $49.54
Item# 008 Part#/Name 72470-S0K-A01 GARNISH, L. FR. 1 1999 Acura TL $49.54
Item# 011 Part#/Name 72930-S0K-A01 GARNISH, R. RR. 1 1999 Acura TL $49.54
Item# 014 Part#/Name 72970-S0K-A01 GARNISH, L. RR. 1 1999 Acura TL $49.54
Again, would be nice if it they were painted parts.
Front door
Rear Door
Front door
Rear Door
Front door
Rear Door
Originally Posted by bkzjimmy
not really....the pillars are just shitty.
99TL-p 114K
Originally Posted by fsttyms1
186,000 miles and mine look like new
Missing Machismo
NiGhT rIdEr
this might help-----> https://acurazine.com/forums/showthr...=carbon+pillar
Originally Posted by TLEXTREME
Where can I find these carbon ones??????
UglyPsycho made his own - "using carbon fiber"
ur one of the lucky ones when it come to the pillars!!! lol
mine are starting to flake too
^ but you did have cracked rotors (albeit aftermarket ones)!
i know you had a lot of track use out of them - just trying to make others feel a little better
after over 70k hard miles and autox on them which is more miles than most get out of their rotors anyway
my irotors arent cracked and they have like 60+k on them
LogicWavelength
3G TL Photograph Gallery
33
11-01-2015 09:38 AM
67326s0ka00za, 67826s0ka00za, 67866s0ka00za, 72430s0ka01, 72930s0ka01, acura, door, fr, garnish, l, outer, r, tape, tl, upper
