door speaker help
Old Jan 24, 2007 | 10:22 PM
S1CK TypeS's Avatar
B A N N E D
door speaker help
Anyone know what the size is for the door speakers? is it 6.5 on all 4 doors? does anyone have DIY for changing the speakers? do i have to take off the whole door panel or can i just remove the grille and get to the speaker that way?
thanks is advance
Old Jan 24, 2007 | 11:23 PM
uncald4's Avatar
Former Sponsor
thanks is advance
6.5" in every door. Well, most 6.5" wont fit in the doors without cutting or spacing. Or both. You have to take off the whole door panel. Front and rear. I would recommend having a professional do this. But if you don't mind taking your time just be careful. As an installer I love to see customers that have already fuct up their car by trying it themselves. I charge them more. Lots more!
Old Jan 24, 2007 | 11:54 PM
BigLizard's Avatar
Moderator Alumnus
I have 2 OEM 6.5s, pm me for pricing
Old Jan 25, 2007 | 12:36 AM
uncald4's Avatar
Former Sponsor
The THREAD WHORE strikes again!
Old Jan 25, 2007 | 08:41 AM
Billy Sacco's Avatar
Kilos of yayo in
Yeah you usually have to remove the whole door panel. I don't know if there is a way to just remove the grill. Its not that hard really to swap the speakers.
Old Jan 25, 2007 | 11:59 AM
S1CK TypeS's Avatar
B A N N E D
can someone with expirience instruct me exactly how to remove the door pannels? uncald4 can you tell me wht speakers fit?
Old Jan 25, 2007 | 12:21 PM
Kilos of yayo in
Well if you look where the door handle is, behind there is a small hole with a little cover on it. You need to pop it open, a small flathead works good for this but be very careful they are really easy to break off. Once you open that you will see the screw, unscew that. Once the screw is out you need to jimmy out the door handle assembly. You will have to remove the the iron rod that operates the door handle, its held on by a small clip. if you look around the armrest there is a hole there and a screw in there. Unscrew that and then you will need to carefuly take off the black plastic covers where the side view mirrors are. Once all that is done pull back gently on the whole door panel and you will feel the clips snapping off. Once the door panel is off of all those you have to pull the whole door panel up to get it off the trim and door lock. Unhook the wire harnesses and there you have it. I know some of this might be confusing so ask if any of it is unclear. Also as far as what speakers fit just keep in mind there is around 2" of clearance behing the speaker with the window down so that will tell you what kind of spacer you will need to use.
Old Jan 25, 2007 | 01:07 PM
missingH22's Avatar
Does anyone know the size of the rear speakers off the top of their head?
Old Jan 25, 2007 | 01:10 PM
dnd2984's Avatar
6.5 inchs
You will need a 3/4 mdf spacer to make a decent speaker fit in there....
Kilos of yayo in
Same size as the front 6.5
Old Jan 25, 2007 | 01:59 PM
missingH22's Avatar
Jul 16, 2017 07:33 AM
soupi
14
Nov 15, 2015 11:15 AM
polish_pat
Sep 25, 2015 12:24 PM
