Doing a jump start for some others is bad for the car?
![Post](https://acurazine.com/forums/images/icons/icon1.gif)
Nothing's wrong with jump starting a car with your car. Just make sure you plug your positive to the battery, and negative to a ground, or else you risk fizzling your computer.
Ed
Acura-TL.com - Forum Moderator
'99 TL Satin Silver/Ebony, Non/Nav, Comptech lowered, Comptech Air Filter Element, Inspire Tails, AEM Brake Pads all around, Comptech Axle Back Exhaust, "Guy Smiley" doll on the dash as my Co-driver...
Pics of my TL
Pics of my Miata! Wadya think?
Ed
Pics of my TL
actually the real reason to make the ground connection to the frame other than the battery has nothing to do with messing up a computer. the real reason you do it is because on the older batteries with the vent caps on top. when you make the last connection between cars there is usually a spark. when a battery has gone dead it realeases hyrdogen fron the vent caps. if you make the last connection on the battery the spark can cause the battery to explode. you can connect the cables to the dead battery posts as long as the other end of the jumper cables is not connected to anything yet. as a good rule of safety make the last connection to the car with a good battery and always connect the negitive cable to a ground connection away from the battery so any sparks wont be near the escaping hydrogen on top of the battery.
formerly 98 prelude type SH
Currently 2001 Acura 3.2 TL With Navigation Black/Ebony
![](http://www.users.qwest.net/~kacampbell/temp/avatartl.gif)
Preludeshfan, that too...in addition, I don't clearly remember the other reason, but I believe it had to do with the different amperages of the starter/alternator, that if one draws too much power, you can fizz the electrics.. I don't remember exactly what it was tho..
Ed
Pics of my TL
Ed
Pics of my TL
hmmm... I dunno. None of my friends have cars that are ghetto nuff for the batteries to die. Our cars usually come with some precautionally features that shut off power when the battery drainage is detected.
![Talking](https://acurazine.com/forums/images/icons/icon10.gif)
By the way, all lead-acid car batteries are capable of emitting some hydrogen whether they're charged or depleated. So just be careful with any sparks around any batteries. I'd hate to see someone post a picture of an exploding TL.
'01 TL with Navi
Naples Gold Metallic
Everything is stock for the moment
except for a big plush teddy bear in the back seat.
'01 TL with Navi
i dunno... that would make for a pretty cool pic, and the owner gets to recieve the book value of his brand new car and then pick up that tl-s
![](http://www.acura-tl.com/ubb/smile.gif)
Aem Short Ram / Comptech Sway Bars / Comptech Springs / Custom Cross-Drilled Rotors / Pirelli SP7000 Tires
Alpine CVA-1005 Head Unit / Alpine G320 EQ / Alpine DVA-5205 DVD / Alpine NVE-N851A Navi / JL Audio XR653-CS 3-Way comps for the front powered by a bridged Alpine MRV-F407 amp / Boston Acoustics 5.5 ProSeries 2-Way comps for the rear powered by Alpine MRV-1002 amp / Dual 10" JL Audio W-6 sub powered by Alpine MRV-1005 amp / Two Alpine CHA-1214 CD Changers
Pics of my TL and Fun/Crazy Pics
