Does anyone knows how TCS work ?
Old Feb 21, 2006 | 12:08 PM
acurabum's Avatar
Hi guys ,
We have a lot of snows lately in Montreal , Canada and my TSC had been activate
a lot lately .Last week I found out my TL-P 02 pull a bit to the right on a perfect straight road ...but today by accident a push on the TSC button which disengage the system and the car drive perfectly with no pull at all ?!?!?...
Is my TSC need care 'cause front rignt brake pad might got jam or stuck ???
Anyone knows how the TSC works and what to do for the maintenance .
Appreciate any feed back.
Old Feb 21, 2006 | 12:10 PM
fsttyms1's Avatar
TCS uses the brake (in abs mode) to controll wheel spin. turning it off shouldnt have made your car go straight.
Old Feb 21, 2006 | 12:30 PM
acurabum's Avatar
Somehow I feel like my right front brake get jam a bit when TSC is on ???
Or I might be wrong . Tonite I will test drive the car with TSC and then without
(It's snowing now ) to see how the direction of the car act . Will let you
guys post , OK.
Old Feb 21, 2006 | 12:31 PM
fsttyms1's Avatar
guys post , OK.
The TCS is only active when there is wheel spin (thats when the light on the dash flashes and you can feel and hear it like abs) If your just driving its not working and it wouldnt be causing any thing
Old Feb 21, 2006 | 01:02 PM
acurabum's Avatar
While there is wheel spin , what will pump the brake to control the car ?
Will this kind of pump get jam somehow or malfunction to the point to
jam the rotor a bit ????
Old Feb 21, 2006 | 01:10 PM
fsttyms1's Avatar
if the system or a brake was jamed turning the tcs off wouldnt undo it. It only works when there is a difference in wheel speed between wheels and only up to 20mph
Old Feb 21, 2006 | 03:50 PM
PenancE's Avatar
noob question, better to leave tcs ON when heavy snow fall?
Old Feb 21, 2006 | 03:52 PM
fsttyms1's Avatar
It defaults on every time you start your car. Just leave it on (unless your stuck, on a hill with ice, or plain just know how to drive with out it on so that it doesnt hinder your style)
Old Feb 25, 2006 | 02:30 AM
PenancE's Avatar
hmmm that night i spun out, i had it off, now in toronto/hamil we gettin heavy snow big fluffy shit, and yea i turn it on now and its wayyy easier. i duno i need better tires////
i gots the assurance tripple tread lol
Old Feb 25, 2006 | 02:59 AM
fsttyms1's Avatar
Designeted snows are much better!
Old Feb 25, 2006 | 02:08 PM
SwampGas's Avatar
/etc/car
I know how TCS works...it works pretty bad.
I drive in the snow, in the mud and in the snow with mud. I always get stuck or slide with TCS on. Turn it off and I drive fine.
Old Feb 25, 2006 | 02:24 PM
MichaelBenz's Avatar
CTS-V Import Slayer
Here is a schematic about it....
https://acurazine.com/forums/ramblings-12/someone-shoot-me-celine-dion-%40-grammys-130030/
Old Feb 25, 2006 | 02:36 PM
PenancE's Avatar
nice find
Old Feb 25, 2006 | 06:57 PM
fsttyms1's Avatar
Not all tl's have VSA.
And the acura TCS is a joke. its the worst tcs system ive used. and its also pointless that its not all speed and shuts off after 20mph in the tl-p
Old Feb 26, 2006 | 12:29 AM
LeonsTL's Avatar
yea if you cant control your car when your goin under 25mph you should be riding the bus.
i nearly spun out goin 70 and i had the traction control off and just swang it and and pulled it straight back into the lane. i was nearly sideways on a two lane road...luckily there was no one comin the other way....
Old Feb 26, 2006 | 10:33 AM
SwampGas's Avatar
/etc/car
Is there a TCS bypass mod?
If not, perhaps a time delay relay that sends a momentary contact closure to the TCS controller when the car is started...then just remove the TCS indicator light wire from the harness?
Old Feb 26, 2006 | 11:55 AM
fsttyms1's Avatar
Just turn the button offevery time you start the car
Old Feb 26, 2006 | 01:52 PM
veo's Avatar
veo
when u press the tcs button does that turn it on or shut it off?
Old Feb 26, 2006 | 02:04 PM
subtledreamer's Avatar
woooo!!
it's always on by default, when you press the button it turns OFF
Old Feb 26, 2006 | 04:26 PM
fsttyms1's Avatar
Old Feb 27, 2006 | 12:47 PM
SwampGas's Avatar
/etc/car
Too much of a pain. A time delay relay would check for voltage from IG-II, wait a few secs, do the momentary contact closure (simulating pushing the TCS button), and trip a holding circuit until voltage loss from turning off the engine...then repeat each time you start the car. To prevent the stupid TCS indicator LED from constantly being on, I assume you'd just yank the wire out of the dashboard harness.
Old Feb 27, 2006 | 01:51 PM
03CoupeV6's Avatar
05 C230K & 09 135i 6MT
Kris, recently I was turning out of a roadway with a really big dip, and I took it an an angle causing one of the front wheels to lift off the ground as the car came out. Since I was pressing the gas, when the wheel came off the ground TCS activated and it felt like the engine shut down for a second.
I've always doubted TCS's ability to cut engine power, but this shows that maybe it can? The RPMs dropped and the car sort of stalled out for a second (TCS light was flashing) until the wheel touched the ground again.
Old Feb 27, 2006 | 02:51 PM
fsttyms1's Avatar
Ive always felt that teh comp was interupting somewhat.
Old Feb 27, 2006 | 02:56 PM
03CoupeV6's Avatar
It can't cut power quite like drive-by-wire can, but it does feel like the computer retards ignition or something.
Old Feb 27, 2006 | 02:57 PM
fsttyms1's Avatar
you wouldnt need drive by wire to cut power, simply cutting the amount of fuel and spark to the engine would retard power alot
Old Feb 27, 2006 | 03:00 PM
03CoupeV6's Avatar
Then that sounds just like what happens. You'd think it would be more effective.
Old Feb 27, 2006 | 03:05 PM
fsttyms1's Avatar
thats what i thought
Yikes
May 3, 2021 04:29 PM
acurajj
Sep 19, 2015 03:47 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
Allen_442
Sep 8, 2015 06:01 PM
