DIY pulling CEL code? Which obd2 pins?
Old May 17, 2009 | 03:29 PM
  #41
@cUr@-TL's Avatar
'99 Acura 3.2TL
Firstly there are codes that don't store, I had to drive around in recording mode to get the TPS code.
The light went on but then went away when the car was restarted.
Then there is the possibility of fubaring the car from putting paperclips into the connector, or the connector.
Finally the battery deal is not 100% it may or may not clear the cel & then you have to reset all your radio presets & in my case two NAV settings.
If your time has no value to you by all means do it this way, for me, I have limited time and having to reset my Kenwood Stereo/NAV (a complex deal that takes 30 minutes now that I have it down to a science) is reason enough to be unwilling except if 100% necessary to do.
So you are saying you created this thread and lived with the issue for three days without opening the hood?
Don't be so defensive! A OBDII reader is definitly a useful thing to have around. It's simply not necessary in many cases!
BTW, there was nothing that coud have been seen even if i had checked under the hood, the plug was still connected to the sensor, just not fully in. I knew the trouble was not something obvious I could just point out by looking at the engine.
Old May 17, 2009 | 03:35 PM
  #42
e30cabrio's Avatar
LFG RANGERS!!!!!!!!!!!
I am merely expressing why I think buying the reader is a good idea.
I am glad your issue is resolved.
Old May 18, 2009 | 08:02 AM
  #43
1st timer's Avatar
UB6IB9
Originally Posted by @cUr@-TL
Yes. But using the paperclip methods does not give you the PXXXX codes. It gives you a number (you count the CEL flashes) and this number equals a P code.
BTW, I have the list if anyone wants it. (Gotta love ALLDATA)
Why pay 170$ when you can do it for free.
unplugging the battery for 5-10 mins will do the same thing, again, for free.
Now guys, i checked the TPS signal on my VAFC2... it wasnt working at all. Looked under the hood, SURPRISE! The connection had came loose.
Problem fixed!
can you send me the list? Nothing wrong with counting flashes
Old May 18, 2009 | 10:29 AM
  #44
1st timer's Avatar
UB6IB9
I got cel today and did the "jump pins 8 -13 method" ,the cel flashes 6 times and a 3-4 second pause and then 6 times 3-4 seconds pause and so on. Is the code i'm getting 006? Also the abs and tcs lights flash while doing this,does this mean anything?
While the cel light goes on the rpm's are higher than normal. I reset the code and it came back when when i played around with the tube going to the short ram intake,in the front of the intake before the tb.
Old May 18, 2009 | 11:00 AM
  #45
MurdaZ's Avatar
ACURA-TL, send the list my way please. i can benefit from it
Old May 18, 2009 | 11:21 AM
  #46
@cUr@-TL's Avatar
'99 Acura 3.2TL
6 short flashes mean code 06. 6 long flashes mean code 60.
higher than normal rpm + tube going to intake makes me think you have a vacuum problem.
I'll post the code list shortly.
Old May 18, 2009 | 11:33 AM
  #47
@cUr@-TL's Avatar
'99 Acura 3.2TL
OK guys.
Here is the complete list of CEL codes for the TL (pdf format). The number between ( ) after each PXXXX code is the one the CEL light flash method gives you.
http://www.mediafire.com/?3ddjvzmryru
Again, here is the procedure to pull the code(s):
1. Jumper the service connector
2. Turn the ignition key to ON
3. Count the flashes on the instrument panel
4. Look up what the code means
the flashes will be a series of long blinks, a pause, followed by short ones. For example:
Long-Long-Long-Long-Long-Long-Long____ShortShort
7 long and 2 short, indicates a code 72, Cyl #2 misfire.
Once you've got the code, you should have a pretty good idea of exactly what the problem is. You can troubleshoot from there.
Old May 18, 2009 | 01:23 PM
  #48
01tl4tl's Avatar
if the tube going to the TB is loose or has a hole or any damage- or the airbox top is broken at a sealing screw, those will cause vac leak- idle surge and poor running
LOOK at the engine-anything loose or hanging off?
tighten everything up- then proceed as needed
Old May 18, 2009 | 01:24 PM
  #49
01tl4tl's Avatar
Codes are CLUES not Diagnosis- example: multi cyl misfire is often just 1 bad coil
Old May 18, 2009 | 02:57 PM
  #50
1st timer's Avatar
UB6IB9
why are the tcs and abs lights flashing when i'm pulling codes?
Old May 18, 2009 | 07:22 PM
  #51
@cUr@-TL's Avatar
'99 Acura 3.2TL
'cuz that's how it is.
Btw, ABS/TCS lights can show codes too (if they're on when the car's running, indicating something is wrong)
For example, my TCS light came on with the CEL. It showed code 31 and 36.. But that was caused by the CEL itself...
Old May 18, 2009 | 08:22 PM
  #52
1st timer's Avatar
UB6IB9
Today the cel went on along with abs and tcs and my car had a hard time to start and when it started the idle was bouncing from 1000 to 2000 rpms.
Old May 18, 2009 | 10:56 PM
  #53
01tl4tl's Avatar
Clean the IACV and look for a new vacuum leak or any wire got unplugged
Old May 18, 2009 | 11:02 PM
  #54
MurdaZ's Avatar
in my opinion, time to do a smoke test. use even a ciggarette and go around the engine.
Old May 19, 2009 | 04:36 AM
  #55
1st timer's Avatar
UB6IB9
I've already cleaned it,but out of curiosity how do you suggest cleaning the IACV?
Old May 19, 2009 | 06:05 AM
  #56
@cUr@-TL's Avatar
'99 Acura 3.2TL
Well check the CEL code man, it should help you find what's wrong.
Old May 19, 2009 | 09:49 AM
  #57
01tl4tl's Avatar
1st--tell us how YOU did it...
Old May 19, 2009 | 06:37 PM
  #58
1st timer's Avatar
UB6IB9
I removed it and sprayed carb cleaner...
IBankMouse
Jun 13, 2020 12:53 PM
SidhuSaaB
May 30, 2020 12:40 AM
SUPRMN84
Oct 7, 2015 09:46 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
scionxb3003
Sep 22, 2015 05:28 PM
