DIY HID kit conversion OEM-After market with pics
03CLS6spd-NBP/B
Okay, I jumped from the CL side to post this, but I felt it relevant since our cars share a similar problem. Oh and I did have an '03 NBP TL back in '03. I too searched in vain to find a good write up on an HID conversion so I did one myself. LMK what you think. Good luck!
https://acurazine.com/forums/2g-cl-2001-2003-50/diy-ballast-oem-aftermarket-conversion-716617/
Confused- about what?
PSCAN- Did you happen to try this: https://acurazine.com/forums/2g-tl-problems-fixes-117/fixing-wet-inverter-ballast-714674/
Nice job, thanks for sharing. Only thing I can think of to improve would be solder splices and possibly using a grommet in the holes drilled to get tighter fit for the wires before the RTV.
03CLS6spd-NBP/B
03CLS6spd-NBP/B
PSCAN- Did you happen to try this: https://acurazine.com/forums/showthread.php?t=714674
I agree with you about the grommet and soldering, my father-in-law (former Ford Factory guy) assured me it would be okay. In retrospect maybe a Ford guy is not the best resource for fit and finish...but I couldn't have done it without his help and guidance so no worries. Thanks and have a good one!
03CLS6spd-NBP/B
Hmmm, that is a good question. From what I can tell the answer is yes. The aftermarket HID bulbs had the same look as the OEM Phillips bulbs as far as how they would fit the harness. A guy on the CL discussion named CL-SA said he uses factory ballasts and after market bulbs to change from 12k, 10k, 8k, etc to change up his look every couple of weeks. He explained that I could use my stock 4300k's if I wanted since they were still good. I will check it out though since he probably has an OEM harness and I have the new after markets and either post it back or PM you. Hope that helps!
03CLS6spd-NBP/B
Is the wiring permanently attached to the back of the bulbs or is that the aftermarket bulb harness? Shouldn't matter though as long as the wires from the bulb plug into the aftermarket ballast.
What kelvin did you get? I got 10,000k's and I must say they are more blue than I thought, but the colors off of signs and stuff are pretty trippy at night...I like! However, the '03 Cl's didn't have foglights for some reason and although they are bright, the visibility kinda blows...fogs would def help.
Good luck with the conversion and keep me posted. You can pm, or call me if you have any questions.
03CLS6spd-NBP/B
03CLS6spd-NBP/B
I think d2c is like a hybrid combo of the d2r/d2s bulbs..one of those where you can use the d2c bulb for either application. Not 100% about that though. Post pics when ur done!
No I didn't try that link, wow I figured a ballast was toast once it went out...good to know! Oh well, my thought was if I was going to have to replace 1 ballast then why not do both at once, but the prospect of $1,000 for 2 OEM or $500/$600 for 2 used ballasts was too much for me to accept. I think and hope it works out in the long run.
03CLS6spd-NBP/B
03CLS6spd-NBP/B
03CLS6spd-NBP/B
OK...the price I quoted you was OEM as well. $324 v $477 each, I don't make up the prices, that is what MY Acura dealer quoted me not including the $250-$300 install. I still got 2 new A.M. ballasts and 2 new bulbs for $179. So in reality..who cares? I did the DIY to show other 'ziners my way to save money and how it was done since both 2nd gen TL and CL owners always search for DIY's with pics to no avail. Why split hairs on differences on OEM prices when this is about an OEM to A.M. conversion. As a moderator I would assume you would both read and realize the intent of my post...evidently not.
ARide for Life
i didnt buy a d2r kit all i did was buy the d2r bulbs so it didnt have any wires, they were 25 bucks shipped. i bought the 9006 kit and that was 55 bucks shipped.
if anyone wants a kit search for ebay member zgperformance, if you buy a kit tell him you were referred by Slow Type S. im about to order a bunch of kits from him for my friends
ARide for Life
you will be better off putting them up for sale on craigslist or ebay because there wont be much of a need for a complete kit on AZ since we all have it stock. id infact get in touch with the guy you bought it from and see if you can exchange it for a 9006 kit for your fogs. if you are putting it up for sale just put it up for the price you bought it at
03CLS6spd-NBP/B
cycdaniel
12-17-2019 10:58 AM
HondoGermany
23
01-08-2016 03:01 PM
