Disappointing TL-S I/H/E/P Dyno & Video
![Unhappy](https://acurazine.com/forums/images/icons/icon9.gif)
went to the dyno for the first time and really dissappointed in my numbers i almost didnt wanna post them up..
i got 197whp and 174wtq my mods are cai ct headers atlp exhaust ur crank pulley p2r tb spacer and gaskets.. ive heard of stock j32a2 making around this much i dont know what could be wrong. this was also done on a mustang dyno and from what ive heard the mustang dyno usually gives higher numbers then dynojet.
well anyways hope u guys can help me out i know that my imrc is opening though and i did seafoam on my vacuum line just last night hoping to clear out the engine a bit before i dyno... however i know i have to change my timing belt and do valve adjustment and plus my side mount is broken
heres the dyno sheet i took with my iphone so not that good quality. i cant get the video to show up but heres the link...
might wanna turn down your speakers.. its reallly loud vvvv
http://s179.photobucket.com/albums/w...t=IMG_0211.mp4
this was my first time so i dont know what any of these numbers mean.. my torque curve looks kinda weird.. the guy said im running rich my afr was 11.6
![](http://i179.photobucket.com/albums/w293/kdawg-/IMG_0212.jpg)
thank u i fixed it just in time.. now try
and a side note my car started driving lil bit sluggish just recently too.. and the guys at the dyno didnt really know how to strap the car down properley. if i show u guys the other video it is scary it looks like the cars gonna fly off the dyno...
i think ima try another place next time
thats what i been thinking too and yup i changed sparkplugs last year to iridium ix and cleaned the throttle plate when i got tb spacer installed and bought a new fujita filter just recently.. its weird because it does feel way more powerful then when i first bought the car stock. i lose traction when i shift to second gear on new tires too its got lots of power but i dont know why it didnt show up on the dyno
the sound quality was bad on the video but i did hear the vtec kik in when i was there. thats where i almost went deaf ahaha.
do you think maybe my intake manifold is heavily clogged up which may cause more fuel then air ratio. ive never ever taken it off and cleaned it. i only did seafoam
you never did the egr port cleaning? and need a motor mount and more importantly the valve adjustment
without those being spot on you lose power
Depending on whats happening it will affect air but you have something else going on
If you have access to a scanner and can drive around with it plugged in...
air filter new but how does it flow?
ck O2 sensor resistance, high enough miles for everything else may need a sensor now as well
remove a sparkplug or 2 and see how they look
you did an ecu reset recently??????--as in, after header or other major mod
the ol clock fuse method is what I mean- then a few weeks driving normal for it to relearn
go somewhere that knows what they are doing!
Dynos can vary by many hp between brands, and even day to day on same machine with change in air temps and engine temp..early morning for highest numbers and fresh synthetic oil eeks out a little more via less resistance
Set tire pressures before dyno too
Who knows when it was calibrated,,especially ones being abused by untrained person
i resetted the ecu about a month or 2 ago after headers and pulley. and when u say drive normal for it to relearn. does that mean no flooring it what so ever? because i think i probably floored it after resetting and idling for a few minutes
and i went around 12pm noon and its about 24 degrees celsius
One thing I have learned in my years around "modding" cars is don't base everything around "numbers" you put down on dyno. Too many factors involved with that.. rather how the power you do have is put down. Dyno numbers vary from day to day too much. Best way to determine your power is to take that thing to the drag strip.
Dragging knees in
Plus drag strip numbers are just as variable as dyno numbers depending on weather, traction, launch/driver skills, etc. At least on the dyno, you are taking the driver variable out of the equation.
Start with the basics. Air filter. EGR ports. IMRC.
Then get an AFR controller and adjust the ratio.
You'll Never Walk Alone
So right now, you still feel that your car is much stronger than when it was stock? If I remember correctly, my friend's S2k with itb's, exhaust, and tune was making 167whp on a mustang dyno.
![Bullshit](https://acurazine.com/forums/images/smilies/bs.gif)
Maybe you are pulling higher numbers, but I seriously doubt enough to keep up with a 335i, although the driver could have been horrible
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
Maybe its juts that your car is old and thats why you aren't seeing the numbers you want. I'm taking it you bought it used? How many miles did you have on it when you bought it?
I've heard stuff like seafoam wont do much if you start doing it when your car has high miles. At that point stuff needs to be taken apart to get a proper clean. Maybe thats the reason? I know when I did seafoam on my car for the first time at 150k miles, I really didnt feel any difference. The most improvement I got on feel was changing the spark plugs. I'm pretty sure I'm running quite below stock numbers.
Also what kind of fuel did you have in your car? Our cars require 91 to get all that performance out of it.
Mustang dyno reads lower. You were probably expecting Dynojet numbers.
I got 225whp with just Comptech CAI and XS Headers on them. You're probably pushing over 240hp with all those mods.
