Dim-Lit Odometer---Help!---
I noticed on my 99' TL-P that the Digital/LCD Odometer/Temperature/Trip meter section right below the speedometer is dim.
I dont think it's wired to the regular interior lights because when i adjust those, it stays VERY dim lit.
At one point, it shut off for about 1-2 seconds, then lit back up.
Are there bulbs that i can replace in there to remedy?
TIA
TIA
I had the same problem:
https://acurazine.com/forums/showthread.php?t=110235
I forgot the part# for the voltage regulator, though. The parts department at a dealership should be able to find it for you. You'll have to take apart the dashboard and gauge cluster to replace it, but it was reasonably easy. Good luck!
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
