Dif between vtec, & i-vtec
Old Aug 19, 2003 | 11:52 AM
Dirk Diggler's Avatar
Can anyone describe technically the difference between vtec, and i-vtec?? I understand that the new TSX has it, and our car doesn't?
Dirk Diggler.
Old Aug 19, 2003 | 03:14 PM
scalbert's Avatar
VTEC is simply the ability to switch to a different set of cam lobes. i-VTEC adds to the standard VTEC the ability to alter the phasing of the cam.
Old Aug 19, 2003 | 03:39 PM
VTEC11's Avatar
what does that mean..
Old Aug 19, 2003 | 03:43 PM
scalbert's Avatar
Basically it is the timing of the opening of the valves in relation to the piston position. Many cars, especially older cars, have a fixed timing of the valves. But with i-VTEC the ECU can control the valve timing within a within of X degrees.
Many manufacturers have their own form of this concept. But not all alter the lift through switching of cam lobes.
Old Aug 20, 2003 | 10:41 AM
So i-vtec sounds way better then. It can make a motor feel stronger at all rpm ranges, where vtec will only work at a certain rpm... correct? I heard the tsx engine feels incredible torquey for it's size because of this feature... must add it to the new TL.
Dirk Diggler.
Old Aug 20, 2003 | 10:45 AM
scalbert's Avatar
That is correct, it does allow for a better torque curve and more linear power delivery over the standard VTEC.
Not nearly as good as BMW's ValveTronic coupled with VANOS though!!!
IBankMouse
Jun 13, 2020 12:53 PM
CatalinaILX
ILX
Oct 27, 2015 02:56 AM
Desert Ridge
Sep 5, 2015 09:47 AM
LAMike240
Sep 3, 2015 04:35 PM
