denso spark plugs?
Old Oct 9, 2003 | 11:36 PM
denso spark plugs?
does anyone know if denso spark plugs make the check engine light come on? i went to the dealer today and the service advisor told me not to use after market plugs because they will miss fire and cause the check engine light come on.
as anyone had this problem or have any advice for me. i need to change my plugs real soon.
thanks.
Old Oct 9, 2003 | 11:52 PM
hzm82's Avatar
Your service advisor doesn't know crap.
Old Oct 10, 2003 | 02:34 AM
Actually this problem happened to me, i had aftermarket spark plugs and caused the engine to miss fire, my check engine light came on, so did my traction control light. I would recomend staying with the factory plugs the have a 100k mile warranty
Old Oct 10, 2003 | 06:20 AM
69tl's Avatar
how about the NGK Double Platinum??
Old Oct 10, 2003 | 02:36 PM
songoku's Avatar
BlingBling INSPIRE 32V
That's BS!!
But I've heard that spark plug needs to be installed by professional because of tha gap.
Old Oct 10, 2003 | 11:30 PM
hzm82's Avatar
Denso and NGK are both recommended by Honda. They come pregapped. If your engine misfired, then its because your didn't torque the plugs correctly.
Old Oct 10, 2003 | 11:34 PM
fsttyms1's Avatar
or gap them properly or one was a bad plug. if i remember right we have a really small gap
Old Oct 11, 2003 | 02:49 PM
yield2s's Avatar
I'm sure the gap is diff between the s and tlp do to compression diff.
Old Oct 12, 2003 | 01:21 PM
anyone installed Bosch platinum +4? How is it? dooes it have any problems with gaps?
Old Oct 12, 2003 | 10:53 PM
69tl's Avatar
i have Bosch platinum +4, i wanna change mine back to the NGK because whenever i step on the gas padel the car feel like choking for like couple sec before start to move.
Old Oct 13, 2003 | 09:46 PM
so, do denso plugs make a difference? will i feel any difference from the factory ngk plugs? or should i just stick with what the dealer gives me?
Old Oct 13, 2003 | 11:24 PM
hzm82's Avatar
Denso IK16 will probably not make a difference since our platinum plugs are pretty good. If you have modifications like I/H/E then you should get colder plugs like IK20. other wise its a waste of money.
Mike734
Dec 10, 2021 01:25 PM
acuratl26
Apr 23, 2020 07:30 PM
ITSJESTER
17
Dec 6, 2018 02:29 AM
Jul 16, 2017 07:33 AM
Joe Avesyan
Sep 29, 2015 03:57 PM
