Debagde
Old Dec 20, 2004 | 12:18 AM
ifski's Avatar
Debagde
Does Anyone Knows How To Take Off The "acura" Signs On The Trunk. I Manage To Take It Off But It Left Behind The Glue.
Old Dec 20, 2004 | 12:23 AM
derrick's Avatar
The search feature on this site is your friend.
Heat up the lettering with a hair dryer (or good 'ol sun will work too on a really hot day). Then gently remove each letter (some even suggest dental tape to cut through). If the double-sided tape is still there, then a grease remover like "Goo Gone' or WD40 should do the trick. After doing that -- take some car wash and make sure you remove any leftover cleaner. Use a wax or polish to protect the clearcoat.
Old Dec 20, 2004 | 03:43 AM
moahdriven's Avatar
i
its not gonna just wipe off with goo gone. I left goo gone on for aboout 5 minutes, tried wiping it off, and eventually just scratched off the "3.2 TL" with my nails.
Old Dec 20, 2004 | 04:49 AM
MADCAT's Avatar
Yeh its very easy.
1. Get a hair dryer and heat up the letters/numbers.
2. Use dentalfloss. Put it between the paint and the numbers. Slowly go back and forth with it untill the letters come off.
3. Use you thumb and rub off the excess glue. And done
Old Dec 24, 2004 | 02:46 AM
ifski's Avatar
thanks for the responce.
Old Dec 26, 2004 | 09:01 PM
TLover8888's Avatar
i used Bug and Tar remover and soaked the remaining glue with it. then, i scratched it off with my nails. next, i used Meguiar's swirl remover to smoothe out the scratches left by my nails. then, i used Mother's polish to shine the area and then Mother's wax to protect it.
Old Dec 26, 2004 | 09:22 PM
VeeralS05's Avatar
I NEED MONEY!
https://acurazine.com/forums/search.php?
ImSneaky
Dec 11, 2012 02:35 PM
gr4mm4t0n
Apr 16, 2010 01:07 PM
Hobogaragesale
Mar 22, 2008 02:04 AM
MeldyS26
2G TL Photograph Gallery
25
Feb 11, 2005 03:32 PM
