Dash issue please help
Old Oct 17, 2015 | 07:35 PM
brent byers's Avatar
New to acurazine and looking for advice I have a 03 tl-p I was looking to change the dash lights to 6000k led but will they work with the dimmer if I think they are to bright and next is can I put a type s gauge cluster in don't see why I can't just Want to ask
Old Oct 17, 2015 | 09:06 PM
Skirmich's Avatar
1.- LEDs should* dim too...
2.- You can install the cluster yes, But the wirings are different since the TL-S uses different gizmos like VSA, Higher Redline.. So its not plug & play into your stock wiring AFAIK.. I could be wrong on this one, Might as well wait for other folks to confirm or deny this.
Welcome to the Forums.
Old Oct 17, 2015 | 10:16 PM
Thanks for the info and the welcome this forum has been very helpful
Old Oct 18, 2015 | 12:39 AM
Dash issue
Found what I needed to know about the gauge cluster after looking around the forum would still like info on led replacements for dash lights
Old Oct 21, 2015 | 09:56 AM
01tl4tl's Avatar
try an outside search engine for LED dash bulbs + acurazine.com
our in-house search wont look for 3 letter sets like LED
Have you tried the DIY section?
Old Oct 21, 2015 | 09:58 AM
Should be small T10 and some maybe T8 bulbs. then go to superbrightleds.com and find the corresponding bulbs and buy em!
Old Oct 21, 2015 | 10:00 AM
Found what I need thank you
Acura604
Aug 28, 2023 03:24 PM
erniek
Nov 6, 2015 08:27 AM
loweredCL
Oct 15, 2015 02:26 PM
dirleton
Oct 13, 2015 10:14 AM
iTHAI
Oct 11, 2015 10:42 PM
