New to acurazine and looking for advice I have a 03 tl-p I was looking to change the dash lights to 6000k led but will they work with the dimmer if I think they are to bright and next is can I put a type s gauge cluster in don't see why I can't just Want to ask
1.- LEDs should* dim too...
2.- You can install the cluster yes, But the wirings are different since the TL-S uses different gizmos like VSA, Higher Redline.. So its not plug & play into your stock wiring AFAIK.. I could be wrong on this one, Might as well wait for other folks to confirm or deny this.
Welcome to the Forums.
Thanks for the info and the welcome this forum has been very helpful
try an outside search engine for LED dash bulbs + acurazine.com
our in-house search wont look for 3 letter sets like LED
Have you tried the DIY section?
