dash board question
Old Jul 24, 2004 | 02:27 AM
dash board question
alright i manage to get open my dash board, b/c I was about to change the thing w/ the colors that i bought on ebay almost a half year ago. The problem is that the point or whatever you called the thing that goes up and down like a meter can't be removed and I don't know which wires should I spliced to connect the power for the dash color thingy. If someone has done it please give me some advice.. or else I'm selling it.
Old Jul 24, 2004 | 08:45 AM
fsttyms1's Avatar
um what??????
Old Jul 24, 2004 | 09:05 AM
SMF-TLS's Avatar
Yada, Yada, Yada
Old Jul 24, 2004 | 11:29 AM
indiglo gauges? needles as in the rpm/mph needles? you need a multimeter to measure voltage coming from the wires from the back of your cluster. that way you can find the + and - to which you wire to your inverter on the indiglos. haha...i think that's what you are talkin bout
bout the gauges, you need to slide into the hole of the indiglows. be careful not to break them or take them off...you will have some serious trouble. it should slide in snuggly.
Old Jul 24, 2004 | 06:10 PM
fsttyms1's Avatar
no you dont need to tap into any wires for them. the back side of the fuse panel has a spot to hook a wire up that is switched with the light switch.
Aug 15, 2019 12:58 PM
BoricuaTL
Apr 8, 2016 01:08 PM
datadr
Sep 12, 2015 09:12 PM
04tler
Sep 10, 2015 01:13 PM
elietania
4G TL Problems & Fixes
Sep 5, 2015 06:52 AM
