Damn Maintenance Light
What your problem is?
I was wondering if this normal for our cars, it just does not seem normal to me since it has never happened to me before. Lately, my maintenence light blinks from the time I put the key in the ignition to about five seconds after I start the car. The light then will then go out, is this how this light is supposed to operate? I had an Accord before and in that car, the light and/or the little color changer came on and remained on till it was reset.
So what is the deal with this? Does the maintenance light come on and stay on in our cars or does the light come on and then turn off? By the way i have a '03 TL-S. I tried to do a search on this, but to no avail....
On the way!
I may be a little off on the exact mileage, but I believe it does that every 6000 miles from the time it was last reset. From 6000 to 7000 it blinks, and after 7000 it will just stay on. It's normal, you just need to reset it.
On the way!
To reset it, turn the key to run and hold down the select and reset buttons for the odometer. After holding the buttons for a few seconds the light should go out.
But remember, it will come back on every 6k or so miles.
holla!
i tried that select and reset thing and heres what happeend, my maintnence light is still on, and my outside temp. reading would go 0, 1, 2, 3, 2, 1, 0, -1, -2, -3, -2 im gettin around to refering to the manuel but is there something diff with a 2000 TL-P w navi or somethin??
On the way!
No. I forgot, you need the two buttons pushed in before you turn the key to the run position.
I always get the temp adjustment and maint light reset mixed up. You did wait till the alternating number went back to 0 before you released the buttons, right? If not, you should adjust your temp sensor back.
mada51589
05-03-2022 08:54 PM
BlkTxAcuraTypeS
10-18-2015 08:05 PM
ahsm
09-09-2015 08:35 AM
dlknight
09-02-2015 10:42 AM
