Damn ball joints!!
UB6IB9
Damn ball joints!!
I change either upper or lower ball joint every 12-18 months!!
Now my left upper ball joint is going again!! Does moog make upper ball joints for a 00 tl? I'm never using oem again!!
UB6IB9
Been like that ever since I got it 9 years ago!!
I dropped the suspension about 1 1/4 3 years ago!
Everytime I doi wheel alignment they tell me everything is ok. Wouldn't they see something if there was something wrong?
Bad roads is likely the culprit unfortunately there isnt anything better than OEM out there. All aftermarket control arms are all China/Taiwan I went through Mevotech, Doorman and OEM. OEM lasted the longest, Sucks that you cant just replace the ball joint you have to replace the entire control arm!
2003 TL-p
ingalls makes good ball joints and control arms. I went through a set of upper control arms, cheap chinese made barely last a few months before the bushings seized and popped out, almost ended badly since i was driving when it happened! Iv been running ingalls adjustable upper control arms with no issues, i recommend those. also check out other products ingalls offers, ball joints, control arms, ETD.
Wrong you Can Replace the Ball Joints Only, No need to buy the Full Control Arm.
I recently changed my 4 Ball joints to MOOG, All my Upper Ball Joint where done for. Now I need a Wheel Bearing!!
OEM Ball Joints Lasted 10 Years!.... Control Arms still OEM.
Hmm since dropping on my tein basics three months ago I noticed a "click" noise over rougher sections of the road or abrupt turns. Was going to replace upper control arm (including ball joint) becuase I figured it could be the joints. Could that be the culprit?
1st timer let me know what you end up buying as I will probably end up getting the same.
As others have mentioned you have suspension issues. Compare components from side to side or to another car, I'll bet you have some accident damage or something off.
Your wheels might look straight, but at rest be putting too much pressure on the joints causing them to deteriorate quickly.
marcelft
07-10-2018 06:17 PM
