Damm..i'm leaking engine oil!!!
Old 02-12-2002 | 01:26 PM
VTEC's Avatar
Unhappy Damm..i'm leaking engine oil!!!
i look under my engine and my oil pan. it look like coming from the drain bolt or the washer. What should i do?? should go to my dearler to buy a set of new drain bolt or washer??
Old 02-12-2002 | 01:30 PM
fla-tls's Avatar
On the way!
Re: Damm..i'm leaking engine oil!!!
Are you sure it's coming from the bolt? Remember, the bolt area is the lowest point on the pan, so it may just be accumulating there from a leak somewhere else...
Old 02-12-2002 | 01:32 PM
NSXNEXT's Avatar
Yeah definitely make sure it's coming from the drain plug.
Does the dealer do your oil changes?
If so take it back to them.
If you or someone else does it, I would first order a new drain plug washer, and if they're not too expensive, a new drain plug.
The worst case is the drain plug threads are stripped and you will need to have a bigger hole tapped for a bigger drain plug. No biggie though.
Old 02-12-2002 | 01:37 PM
VTEC's Avatar
Unhappy
i did my own oil change. and i'm 99% sure it is coming between bolt and the washer.
like NSXNEXT said i'm go get myself a nex set of bolt and washer.
Old 02-12-2002 | 01:39 PM
NSXNEXT's Avatar
VTEC,
Since you change your own oil, might I suggest you order quite a few of the crush washers. You should be replacing it everytime you change the oil. They are very cheap insurance to prevent you from stripping the oil pan threads.
Old 02-12-2002 | 02:29 PM
Closer's Avatar
Yeah, you're supposed to change that crush ring every oil change.
Old 02-12-2002 | 02:54 PM
stevebo's Avatar
If it were me the first thing I would do is crawl back under there with my torque wrench and check the torque.
Old 02-12-2002 | 02:57 PM
stevebo's Avatar
I used to change my own oil without a torque wrench until I stripped the threads on my old crx. At the time there was not meat to put a bigger hole so I had to pay $800 for a new pan!!!
That buys a oil change or two!
Since then I spent $50 on a torque wrench.
steve
Old 02-12-2002 | 03:04 PM
VTEC Animal's Avatar
I know that every time I get the oil changed at my dealership they replace the little rubber gasket/washer to keep from leaking. They also replace the rubber seals oil filter too. That's all standard at my dealership and I think they charge about 45 cents per gasket/washer..... It's worth the 45 cents to avoid headaches, I agreed with them on that idea....
Old 02-12-2002 | 04:24 PM
VTEC's Avatar
Smile
Wow i don't know that. i have to change it every time i do my oil change. and yes i have a torque wrench.
Thanks alot guys.
Old 02-12-2002 | 05:27 PM
BLEXV6's Avatar
I guarantee if you did not change the aluminum washer, that this is the likely source of the leak. Been there and done that with a previous Accord.
fifer16
1G RL (1996-2004)
10-16-2015 08:54 AM
IIDXholic
10-08-2015 07:53 AM
pizokk1
09-17-2015 09:29 AM
datadr
09-12-2015 09:12 PM
michaellong77
1G CL Problems & Fixes
09-11-2015 12:54 AM
Quick Reply: Damm..i'm leaking engine oil!!!
