D2R vs D2S vs D2C : bulb replace?
Old Jan 7, 2008 | 11:31 AM
websters03's Avatar
So i need to replace my stock HID bulbs and i know they are D2R bulbs. i have a thread in BM trying to find some bulbs and i was told by a 3G TL member that the D2S And D2C bulbs will work also. Is this true? Are there any mods that need to be done to the bulbs or is it jus plug and play?. . . .(tried to search but cant use "hid, d2r, d2s," etc.)
Old Jan 7, 2008 | 11:41 AM
fsttyms1's Avatar
they all work. If im not mistaken the D2S needs a groove cut into it. The D2C is designed for both
Old Jan 7, 2008 | 12:25 PM
websters03's Avatar
sweet thanks fsttyms i knew u had the answer, i was gonna jus send u a pm but didnt wanna jam ur box.
Old Jan 7, 2008 | 12:32 PM
websters03's Avatar
so would i just match the bulb case of the D2R bulb to the D2S and cutt matching groove(s). using an exacto knife? im sure its something i can do jus need alil guidance.
Old Jan 7, 2008 | 12:36 PM
01tl4tl's Avatar
Do not attempt to modify the bulbs in any way!!!!
D2C is replacement for D2R and D2S bulbs,
there may not be a locating notch so just put them in like the old ones came out and put the spring retainer clip in place
use headlights or low beams as your search, and complete install instruction will be found
Phillips 4300 is stock many of us use Kaixen 5000 or 6000 for a more intense bluish white light- better to see at night
see our vendor Excelerate for Kaixen bulbs
Old Jan 7, 2008 | 12:44 PM
websters03's Avatar
ive taken apart the headlight housing and installed d2r bulbs before, thats not my concern. im considering buying a set of d2s bulbs from a member on the BM. i just want to be sure they will fit and work in our housing? ive never seen the d2s bulb and i know the d2r does have grooves on it. soo ur saying it will fit like normal and the spring clip will hold a D2S bulb in place with NO modification?
Old Jan 7, 2008 | 01:05 PM
fsttyms1's Avatar
Some have installed them, the grove on the S is different than the R. The ones that did had to cut a grove into the bulb to fit. I would look into a R or C myself.
Old Jan 7, 2008 | 01:11 PM
websters03's Avatar
oh well that doesnt sound as promising now. . . i think ill take ur advice and stick to the R or C.
Old Jan 7, 2008 | 01:24 PM
websters03's Avatar
can anyone that has done a D2S fit give me pointers?
Old Jan 7, 2008 | 04:16 PM
fsttyms1's Avatar
Its nothing more than filing a notch in the base of the light. If you do a search i know the pic of what needs to be done is somewhere here (as ive seen it before)
Old Jan 7, 2008 | 05:02 PM
probmxstyle's Avatar
Am I missing something or is there a advantage over the diff typed of bulbs.
Old Jan 7, 2008 | 05:23 PM
fsttyms1's Avatar
no advantage. they were just designed for different housings
Old Jan 8, 2008 | 07:08 PM
websters03's Avatar
thanks for the info but i jus went ahead and bought the d2r.
Old Jan 8, 2008 | 10:07 PM
Razzi's Avatar
T-Swzy
man this makes me angrier, first stupid different wheel bolt patterns, then SAE vs Metric, then just stupid differences for no reason
Old Jan 9, 2008 | 07:34 AM
fsttyms1's Avatar
What??
Old Jan 9, 2008 | 11:16 AM
01tl4tl's Avatar
I think Razzi needs one of those Daylight bulb desk lamps that fight the winter blues in blizzard country- I know mine helps, and it only rains here! 25 bucks well spent IMO
Odd combos of bolts and stuff result from jap cars being built in america
Bulb differances are typical manufacturing bs- bmw requires one type- half the world something else....
Old Jan 9, 2008 | 01:42 PM
Razzi's Avatar
T-Swzy
lol i get plenty of sunlight here in minnesota, just too much damn snow ruins my mood.
what i was rambling about was that there isnt a universal somethin somethin ya know. silly differences that makes working with cars so damn hard
Old Jan 11, 2008 | 10:29 AM
ENISHO-TEE's Avatar
anyone notice that the oem d2r bulb come with the glare shield. I recently installed the d2c kaixen 6000k that didnt have the glare shield. which explain why i'm getting high beam by the oncoming car.
Old Jan 11, 2008 | 11:42 AM
fsttyms1's Avatar
There is, its the D2C. Thing is is the bulbs S&R are designed for different types of housings
fsttyms1's Avatar
And maybe your lights arent aimed properly? I havnet gotten it from any one
Old Jan 11, 2008 | 12:50 PM
01tl4tl's Avatar
If you have lowered the car and not re-adjusted the headlights correctly, chances are you will get beamed by others.
This can happen just from worn shocks too.
If the lights are aimed right- its usually someone who has never seen these kind of bulbs up close~ that thinks the you have hi on. Whats really funny is how weak the Hi beams are in comparision- and all they do is add more light, not replace the low beams on
I noticed on some years there is a shroud in front of the bulb- but thats its own piece, not the bulb. Is that what you are talking about is missing?
Old Jan 11, 2008 | 05:56 PM
Excelerate's Avatar
Former Sponsor
Here is a little incentive for all of you looking for D2C bulbs.
https://acurazine.com/forums/sponsored-sales-group-buys-10/kaixen-d2c-hid-replacement-bulbs-groupbuy-382374/
Old Jan 11, 2008 | 06:07 PM
aznboi2424's Avatar
wouldnt lowering the car also lower the beam of light?
Old Jan 13, 2008 | 11:24 AM
ENISHO-TEE's Avatar
My 02 tl-s is lower with H&R sport springs. To accomidate the lowered ride height, I've adjusted the beam as low as I could go without sacrificing visiblilty. drivers that are hi beamin me are SUV,TRUCK and cars with foglite combo. i have the combo as well.
Old Jan 13, 2008 | 11:31 AM
ENISHO-TEE's Avatar
it look like a dark brown blackish hi temp sticker on the bulb.not the shroud in front of.
Old Feb 15, 2012 | 10:49 AM
kane337's Avatar
2007 Acura TL
I ordered some D2S 6000k bulbs recently and got D2C's. I was about to call the vendor back but decided to research first. I found this information on the Honda tech forums regarding the differences between D2S, D2C and D2R bulbs.
Just thought I would share.
http://honda-tech.com/showpost.php?p...37&postcount=5
D2R = D2 bulb for Reflectors (like the IS300's or the Prius, notice the ceramic painted part of the bulb for light control)
D2S = D2 bulb for Shielded housings aka projectors (notice no paint)
D2C = D2 aftermarket bulb, C generally standing for colored (6000K and up) but it also means the base has notches to fit in both R or S housings.
D3 and D4 bulbs are Non mercury versions of D1's and D2's, it's said they'll need new ballasts to be used but people on hidplanet have said and shown pics of their D4's lit up on their Hella Gen 3 ballasts.
Old Feb 15, 2012 | 05:55 PM
Skirmich's Avatar
Yes any D2C would have some amount of Glare, Not even aiming would help it seems the D2R Shield + The Shield on the Headlight Itself helps to eliminate Glare on a 90% (Totally IMO).
But Installing D2C Bulbs will get you some amount of Glare..
Now Enough to bother Oncoming Traffic? I highly Doubt it, Those must be more annoyed with the KV rating...
Old Nov 12, 2016 | 08:00 AM
bbsitum's Avatar
I did read at internet recently how XXR and XXS have different hausing lenses and should not be exchanged.
Old Nov 12, 2016 | 07:08 PM
Skirmich's Avatar
D2S is made for projectors but the bulb dimensions and light output is the same under the D2 family..
The issue with D2S is that the bulb socket does not fit plug and play to D2R that is what D2C is made for as is the universal type for both sockets.
Old Nov 12, 2016 | 09:22 PM
01acls's Avatar
Reflector Headlamps D2R - notice the shield on the bulb to control unwanted light (glare).
Generic bulb - one way to tell the bulb is of a lower quality is that it does not have metal support tabs at the base of the glass bulb. Projector Headlamps D2S/D2C - shieldless bulb.
Old Nov 13, 2016 | 09:58 AM
bbsitum's Avatar
So what I actually learned this days. When I get car I taught former owner set white bulb from 900X series. Well when one of white bulb die I would buy two regular. Actually bulb didn't die then work on off. So went to car part store and ask for price of headlight low beam bulb for Acura tl 2003. Car parts store should be trained to say such things in a careful way. Price of 100$ bulb hit me to hard and I'm still recovering. There is not hope go to U-pull find the bulb. I went to 3 different U-pulls and one had cars with d2r that come day before. Bulbs are gone. Mafia evidently cower U-pulls hid bulbs. I found and order a philips d2r from home depot for 42$+tax. So I went from 8$ bulbs in every store to one week wait for 50$ bulb. Lucky me.
oo7spy
Jun 19, 2023 12:48 AM
pplcrew
Jan 30, 2021 08:59 AM
brjones9
Sep 3, 2015 07:30 PM
pesobreeze
1G RL (1996-2004)
Sep 3, 2015 12:26 PM
voigt
Sep 2, 2015 10:44 PM
