are d2r and d2s interchangeable?
Agean Blue Bishes
1 Post
just browsing through some pictures of bulbs and the reflective ones have some coating to not give as much light.
check it out
D2S (left) D2R (right)
do they work in the same holder or no?
i would immagine that the projector ones would be brighter since more bulb is exposed.
check it out
Originally Posted by demolition_x
are the results worth it though?
This is the same effect HID reflector vehicle owners "attempt" to duplicate by going with higher Kelvin bulbs(6k,8k,10k), which results in less usable light and more of a blue/purple tint.
Projectors use standard 4300k exaclty the same that comes on our cars stock, just that again... due to the projector housing and the cut off shield, they get the blue/purple flicker, without compramising maximum light visibility on the ground.
How about us 99-01 owners that have the large difuser in front of the bulb?
If you look at the two bulbs, you would notice a strip of metal, along the side of the D2R bub, this also aids in controlling light output. The D2S does not have this strip, again, because of the projector and cut off shield, it's not necessary.
I think someone should try it
Future JDM Whore
Originally Posted by dnd2984
How does the 99-01 housing look without the difuser, and would the light output be wild.
Why would anyone want to fuck up their lights by removing diffusers or using the wrong type bulb? This is one of the mods that will affect other drivers. I wonder if they can take you to court and win if they hit something while blinded by your unapproved lighting.
Agean Blue Bishes
1 Post
i can't see how it can fuck up the housing. i really can't see it making that huge of a difference if more bulb was exposed. there is a diffuser any ways so its not like it is just the bulb and reflector shining light. the bulb gets its light shined back and forces it to reflect.
im kinda curious what the difference would be
the masking is there to block stray light to achieve a correct cut off in the reflector housing. If you put clear light in the reflector the effect will be more glare for other drivers.
I've been running Osram d2s bulbs in my 99 for about 4 months now. The main reason I got the d2s bulbs is because they were cheaper than d2rs (got them off of ebay). I had to modify the base with a dremmel. This took about 30 seconds. As for as brightness, I really can't say. Mine were much brighter than my stock bulbs, but my stock bulbs were 6 years old and had some chalky looking build up in them. One of them had turned pink. I would say that i have been bright lighted 2 times in the past 4 months, so the glare must not be that much of an issue.
My "P" SpAnKs YouR "S"
Chloe @ 17mo
Originally Posted by TL_Fo_Life
calm down homie. If you wanna be mad at someone, be mad at the driver of an suv/lifted truck/18 wheeler/cop car/ufo. Sue them for, glare from their headlights.
Originally Posted by Da_iLLeZt_TL973
aaron and 00redtl have the diffuser removed do a seach and look for their posts in the picture gallery....i remember driving to AC with aaronn and i saw the way the beams look its crazy instead of shooting one beam you get 3 seperate beams spread out all over the road and you get a bright light at night so no need to raise the beams or use high beams
but now i retrofitted projectors so im using D2S's. for a while i used OEM D2r's but only shaved.
removing the diffusers doesnt really make things that much worse. just gets time to get used to. its definitly brighter than having the lame halogen look diffusers on. it makes us look like those old-school ricers with autozone cheap blue bulbs..
noobs are getting worse these days on AZ.
i like this idea
any more info?
any more info?
Originally Posted by tiguy99
it says:
"The main difference is the U-shaped masking on the D2R that blocks out unpredictable light in certain directions. Also, the base has different notches. Name of base is P32-d2 for D2S and P32-d3 for D2R. D2R was developed so that Mercedes could still use their reflector based headlights in the mid 1990s"
So if you put D2S line in TL and it will cause glare. Nothing to "experiment" here
quanaman
01-09-2023 07:33 PM
pistacio
09-26-2015 09:45 AM
gehrlichman
09-22-2015 10:08 AM
