Cut it for cold air?
Old Dec 6, 2005 | 08:53 PM
initialD's Avatar
what you think if i cut and open the fake hole (which is under the foglights 02+)for the cold air directly blow to the CAI,will it gain a little hp??thanks
Old Dec 6, 2005 | 09:18 PM
fsttyms1's Avatar
wouldnt hurt to get more fresh air
Old Dec 6, 2005 | 09:22 PM
Pure Adrenaline's Avatar
Dragging knees in
It actually is cut open on the top side and it delivers air. But if you want to widen it by cutting off the tab, thus increasing the windspeed by 1.384 mph to the filter, then by all means.
Old Dec 6, 2005 | 09:25 PM
blueglows's Avatar
SOLD 9/11/06 Parts 4 Sale
only good can come from it...go for it!
i take that back... water can get in easier... especially car washes
Old Dec 6, 2005 | 09:30 PM
JimmyTLS's Avatar
You can remove the foglight altogether. But make sure you have a bypass valve or something. Hydrolock will suck
Old Dec 6, 2005 | 09:39 PM
sbuswell's Avatar
I need 2 more gears
Good idea. Try it and let us know if it works. I hope it does but probably will wear your filter out faster. Unless you have an icebox.
Old Dec 6, 2005 | 09:44 PM
ou sig's Avatar
Boomer SOONER
ya it will give more air to the filter but I dont think it would be worth it because of how fast the filter would get dirty and if you drove through a rain storm or the car wash, there would be nothing to protect the filter....dont do it there is plenty of places for air to get to the filter the way it is
Old Dec 6, 2005 | 09:55 PM
Dragging knees in
Hook up an air duct from there to the brakes. Oh, yeah, baby.
Old Dec 7, 2005 | 08:30 AM
SK2003TypeS's Avatar
....great, I've had my driverside foglight out for a few months. Probably adds to my poor gas mileage as of late.
Old Dec 7, 2005 | 08:54 AM
fsttyms1's Avatar
that wouldnt cause worse mileage, unless you are constantly flooring it to see if it makes a HP difference
Old Dec 7, 2005 | 09:01 AM
-Rz-UA5's Avatar
As far as daily driving, it should be okay.. cause i had mine open for a long time, i've drived in the rain, washed my car.... everything seems fine, unless you drive you TL like a submarine. Performance wise, I think the car is smoother in acceleration. at least my butt dyno tells me so..
Old Dec 7, 2005 | 10:03 AM
No, you're right. I'm having a different mileage issue. I'm at like 150 miles on this tank and pretty close to having the light come up. I'm usually at about 230 miles at this point. Will see what happens next tank. Maybe it's adjusting to the cold.
Old Dec 7, 2005 | 10:17 AM
optomos's Avatar
I=X - optomos
150 & 230? Wow....and I complain about getting 320-340
Old Dec 7, 2005 | 10:35 AM
Yeah...getting a little concerned. I'm able to deal with the fact that I normally get between 18-20 mpg. I only can get above 300 when doing straight hwy.
Sorry to the orignal poster.
Old Dec 7, 2005 | 11:31 AM
@cUr@-TL's Avatar
'99 Acura 3.2TL
18-20mpg
that's fuckin low man get ur car checked or ease off the gaz... hell a 5L V8 can get better milleage than that!
Old Dec 7, 2005 | 11:33 AM
ou sig's Avatar
Boomer SOONER
Originally Posted by @cUr@-TL
18-20mpg
not in town - I think that is what he was talking about. I get about that in town - usually more like 20 even actually
Old Dec 7, 2005 | 11:38 AM
I usually get 18-20 in city. Been like that since I bought the car in Nov '02. I don't open it up that often.
Old Dec 7, 2005 | 12:53 PM
Dragging knees in
You guys are too pampered. My gas gauge needle is about a quarter of its way down from the max line (and I filled it up all the way, beyond that line) and I've only logged 38 miles so far. At this rate, I'll get like 11 mpg.
Why? Because I start my cold ass engine, then drive a mile to class, park it, then do it again on the way home. x 3-4 more times everyday.
My car hates me.
Old Dec 7, 2005 | 01:15 PM
snowman81's Avatar
Sippy Cup (x2)
I normally run about 22 mpg city but with all the long drives I've been taking recently I am getting 29 mpg consistently.
As for the cutting the whole to let more air in, I wouldn't do it. As someone already said, they are open on the sides and the top. I would be to afraid that it would get dirty to quick, especially in the winter time up here with all the sand and salt on the road...no thanks. Not sure where you're at though.
Old Dec 7, 2005 | 01:41 PM
z3Ro's Avatar
Mr. 2tone
ive done that cut out on my 01 tl...n my filter hasnt gotten that dirty yet...its pretty kool...but u might wana reinforce the flaps which covers that area...u know...the flaps that r part of the wheel weld...kuz those will just blow rite out n get dragged on the ground...even worse is getting it sucked by the tire...ripping...the wwhhoollee weld off...lol...
Old Dec 7, 2005 | 01:57 PM
I have a very similar commute.
Old Dec 7, 2005 | 02:38 PM
mr.motoring's Avatar
checkmate...
My 03 Type-S with 32K on the odo did Houston to Baton Rouge to New Orleans this summer at 80-90 MPH with the AC on and moderately accelerated passing and arrived with gas to spare. Add up the distance and it comes up to 400+ miles to the tank. Blame it on the crappy but friction-efficient OEM Michelin's and extended use of 5th gear. And possibly drafting (safely I must add) much of the left-lane traffic until they yielded to my right of way!
Old Dec 7, 2005 | 03:14 PM
fsttyms1's Avatar
You also need to remember that they have switched to winter formulas for gas, which will lead to lower mileage. Also try different fuels. Try to find fuel with out ethanol in it. My motor hates the 10% mixture and gets horrible mileage with it
Old Dec 7, 2005 | 03:48 PM
The Exxon I've been using since I've had this car has the 10% label on the pump. I would've thought they switched the mixture a while ago.....maybe they did it recently.
The concern is going from my normal ~230 per tank to what looks like is going to be ~160 this tank......kind of a drastic swing and I haven't had this problem the past few winters.....If anything, just a few miles here and there. Probably should check my tires as well.
....and horrible mileage for you is what ?....like 375 ?...LOL
Old Dec 7, 2005 | 10:22 PM
joseph_99tl's Avatar
didn't someone on this forum do that?.
Old Dec 7, 2005 | 10:58 PM
initialD's Avatar
I think i will,i can do only 300km per tank.95%city 5%HW and VTEC kicks in apporx 50times per tank.
Old Dec 8, 2005 | 03:46 AM
MikePA's Avatar
Opening up the hole will cause you to lose downforce on the front of the car. This will cause the car to go from neutral or loose to tight. Oops, sorry, I thought I was on a NASCAR forum.
tsx_boy
Dec 13, 2019 08:33 PM
Jul 16, 2017 07:33 AM
rcs86
Aug 2, 2016 06:52 PM
hashbrown
Sep 29, 2015 12:13 PM
jmaxima03
Sep 27, 2015 10:22 AM
