Customizing Headlights!!!
Old Jan 23, 2001 | 07:32 AM
3point2TL's Avatar
Post Customizing Headlights!!!
customizing headlights!!!
hey guys like it says, i'm customizing them. I've removed the shell but DOES anyone have any suggestions on how to scrape off the excess silicon sealing from the front clear plastic??? BTW prying the headlights apart is a pain in the A$$. thanks
3.2 Tl
WW Kit
Fogs
Tinted Tails
White Signals
Clear Orange DRL's
Custom Grill
Old Jan 23, 2001 | 09:21 AM
BlackShadow's Avatar
O.G.
Post
If you are planning to take the diffuser off of the headlights, the beam pattern will get ****ed up. One member did it to his TL and he is regretting it. If you are not taking off the diffuser then disregard what I said before.
BTW, what customizing are you doing to your headlights?
When you are done post some pix!
Old Jan 23, 2001 | 10:51 AM
TommyAmrani's Avatar
Post
i think he means that he cleared em out...
Old Jan 23, 2001 | 12:39 PM
3point2TL's Avatar
Post
Yes, I'm considerering removing the defuser, but will it blind other cars and will I have trouble seeing the road (because the light is too focused on one area?) btw ill post the pics as soon as I'm done.
3.2 Tl
WW Kit
Fogs
Tinted Tails
White Signals
Clear Orange DRL's
Custom Grill
Old Jan 23, 2001 | 12:52 PM
O.G.
Post
Hey 3.2TL, I think you should wait about taking out the diffuser. Talk to the member who took his off first and then decide if you still want it. I believed he wanted to put his diffuser back on. I don't want you to make the same mistake so ask around first.
BTW, can you post a pic or a link of your WW kit from all angles because I am deciding which kit to get (WW, OEM, etc...). And how much was your WW kit? Thanks bro.
Old Jan 23, 2001 | 01:10 PM
Guest
Guest
Posts: n/a
Post
Does anyone have pics of the light w/out the diffuser?
Old Jan 23, 2001 | 06:35 PM
VDo's Avatar
VDo
Post
Don't do it!
'00 WDP TL
K&N filter, Flowmaster mufflers, Neuspeed springs, WW spoiler, PIAA 1200 fogs w/OEM switch, Inspire taillights, M3-style mirrors, Custom grill and headlights
Old Jan 23, 2001 | 10:42 PM
O.G.
Post
Thanks VDo, you're the guy I was referring to for 3point2TL about removing the diffuser.
Old Jan 23, 2001 | 11:35 PM
TLon19s's Avatar
Post
I cleared out my headlights and removed the lens. I personally like the look of the headlights. But your right it does mess up the beam, projects like a W beam.
Old Jan 24, 2001 | 02:12 AM
KUMO's Avatar
Post
hay~ VDo after you take the factory seal off and than put them back on. is the light get fog inside. if you don't have this problem tell me how you did your light. because I want to do them too. thanks
2000TL non-navi black w/WWkits/ WW flash mount wings/Ground control coil overs/$10,000 stero systems/racing heart 18" T5/momo milleuium sterring wheels/indiglo signs/razo shift nob/Comptech sway bar/AEM CAI/AEM pullys/more comming soon.
Old Jan 24, 2001 | 06:17 PM
3point2TL's Avatar
Post
vdo, so why not remove them. I have them off already, I'm just debating whether or not to put them back on when I seal it up. How's the projection??? can you post a pic of the area the light covers?? thanks
Old Jan 24, 2001 | 06:18 PM
DragonTL's Avatar
Post
you don't want to do it. Trust all of us.
2000 Acura silver TL
CL-S rims
Comptech Springs
Factory bodykit
Inspire Tails
Burlwood knob
Tint
Old Jan 24, 2001 | 09:30 PM
Hiroki's Avatar
Post
why not removing the diffuser? i think it looks better.. btw are the inspire tails easy too install?
Old Jan 28, 2001 | 12:45 AM
SLVR TL's Avatar
Post
Like someone said, the beam pattern gets f'ed up. It looks cool but if you can't see at nite, then you're doomed. If you don't drive at night... go for it.
Old Jan 28, 2001 | 12:53 AM
Gomez's Avatar
Post
Whay would you remove the diffuser?!? Some engineering group probably spent a lot of time designing those things so that we can see better!
This reminds me of the guy that wanted to remove one of the tail pipes so that he would only have one, thus defeating some nice (and expensive) engineering that makes the car better than most...
Gee, while you're at it you could also remove the windshield wipers, shave off the jacking points, install a mast antenna and scrape the painted one off, change the HIDs to halogens and modify the engine to run on diesl instead of gas.
'01 White Diamond Pearl 3.2TL
-Wing, tint, burlwood shift, Whistler 6-band
'88 White RX-7 Convertible
-Permanent tinitus courtesy of Rockford-Fosgate
Old Jan 28, 2001 | 01:02 AM
SLVR TL's Avatar
Post
hehehe
some ppl will do almost anything to look different.
Old Jan 28, 2001 | 04:09 AM
3point2TL's Avatar
Post
good point, I've already decided to leave the diffuser in. It is meant to spread out the light evenly across the path. haven't tested my theory, (being that my car is still inthe shop), but I think that's what it does. besides, the diffuser would make the blue/purple/white ??? lights (soon to be)inside look better
3.2 Tl
WW Kit
Fogs
Tinted Tails
White Signals
Clear Orange DRL's
Custom Grill
Old Jan 28, 2001 | 04:24 AM
3point2TL's Avatar
Post
PS
THAT'S WHAT THIS FORUM'S FOR!!!
thanks guys
Old Jan 29, 2001 | 12:13 AM
Hiroki's Avatar
Post
hmm i see your point i tried it out on my other car, it was heading to the scrap as soon as my brother buys a car so i did it.. anyways the beam is super narrow so if you're driving at night without streetlamps than it looks like youve got tunnel vision or sumthing, very dangerous
btw no one answered my other question, are the inspire taillights easy enough to instal so i can do it myself?
Old Jan 29, 2001 | 01:14 AM
DragonTL's Avatar
Post
The taillights are very easy to install, so go for it. The screws you have to undo are very obvious. good luck
CL-S rims
Comptech Springs
Factory bodykit
Inspire Tails
Burlwood knob
Tint
Old Jan 29, 2001 | 03:31 AM
3point2TL's Avatar
Post
Hiroki,
you have to remove the cargo net screw, then some of the plastic walls behind the tail lights then you can access the screws. be careful not to drop the nuts or bolts down between the wall, it's a pain to retrieve!!! good luck.
3.2 Tl
WW Kit
Fogs
Tinted Tails
White Signals
Clear Orange DRL's
Custom Grill
Post
Easy to install, it's just that the Blinker plug is to small for the Inspire Tail plug, I just put some double sided tape from 3M(made a cut out of the blinker plug) and it fits snug now, It takes about 30 mins. At first I was like "man that's some $$$$ for tail lights but I don't regret it. It just changes the looks of the whole car(from the rear) and I don't think anyone has them in Hawaii
tann@808-'00 TL
non-Navi(Doesn't work in Hawaii)
Factory body kit & Wing, 19" Racing Hart C-5's,
Nitto 555's, CompTech Springs, CompTech Exhaust,
CompTech Headers, Inspire Taillights, NOS(70 shot),
AEM CAI, Alpine 8080, TL rear door handles in front,
5% + 30% tints,30% front windshield.
tann@pixi.com
Old Jan 29, 2001 | 07:45 AM
F=ma's Avatar
Exclamation
Don't be so quick to judge.
The dual exhaust we have is non-functional. It would be just as high flow if it were a single. The piping is 2.25" which is good enough power recommended to around 270-300 hp.
It is dual for aesthetics only. And even then, not everyone agrees that dual exhausts look better. It is my opinion that a Single exhaust is sportier. Hence IS300, BMW 330, Supra, Skyline... And the more luxury rides have duals, GS400, LS400.
I agree with the diffuser argument. The diffuser actually has a purpose. To evenly distribute light. But the 2nd exhaust does not, other than to give the car a more luxury appearance. As you can imagine, with the crowd we have here (performance enthusiasts) some of us are looking for a more sport oriented vehicle, or at least a greater flavor of sport from our car.
It would not supposedly 'defeat engineering that makes our car better than most'. Hell adding a kit makes our car scrape on driveways, thus giving it decidedly INFERIOR ground clearance to nearly every other car on the road. Why would any moron pay $800-$1000 for inferior ground clearance.
The argument holds for any number of modifications.
Kenny
TL
<FONT COLOR="#800080" SIZE="1" FACE="Verdana, Arial">[This message has been edited by F=ma on January 29, 2001 @ ]</font>
Old Jan 31, 2001 | 01:46 PM
VDo's Avatar
VDo
Post
Hey, sorry it took so long to respond. I totally overlooked your post. Anyway, I have had no problems with fogging of the headlights and it's been 6-7 months with tons of rain and washes. Just make sure you seal up your lights up good. Before for reseal the headlights, heat up the factory glue and then tie/clamp the pieces together. This should form a decent seal as is. But to be safe, after the lights cool, add an addition bead of silicon around the edges making sure there are NO gaps.
'00 WDP TL
hashbrown
Feb 18, 2022 11:20 AM
Jul 16, 2017 07:33 AM
Mr.Tea
Oct 2, 2015 10:32 PM
h22lude
Sep 27, 2015 06:22 PM
