Cruise Control
Old Apr 13, 2014 | 10:35 AM
Nemesis TL-S's Avatar
Cruise Control
Help, my cruise control doesn't work anymore. The cruise light on the dash comes on when I press the button but it doesn't do anything. Also, I don't know where the cruise control motor is to check if any of the connection have come lose. Can someone please help me with this?
Old Apr 13, 2014 | 12:37 PM
Nicks2001tl's Avatar
The cruise control module is located directly behind the windshield washer fill tube. Also check to see if the cable is connected to the throttle body.
Old Apr 13, 2014 | 06:37 PM
Skirmich's Avatar
Look for your side Motor Mount its a black box installed in a "Y" shape cross bar.. It says "Honda" on top of it and it has a Cable that comes out from it then goes on top of the radiator then it turns on top of the air filter box and ends in the Throttle Body..
If yours isn't engaging even if the Cruise light comes on then you got to look if the motor isn't stuck or if the throttle cable isn't rusted..
Old Apr 14, 2014 | 02:47 PM
Thanks, I'll check and see if anything is disconnected.
Old Apr 14, 2014 | 03:29 PM
03blackbeast's Avatar
Is the light coming on that says cruise engaged? If not then it's not receiving signal from the steering wheel control and you need to work on the steering wheel.
Old Apr 14, 2014 | 04:08 PM
Hi guys and thanks for your help!! You helped me find the problem. The plastic thing that holds the throttle cable is broken. I don't know what it's called or where to find one. Does anyone know?
Old Apr 14, 2014 | 07:38 PM
Does anybody know what this thing is called or where to buy a new one?
Old Apr 14, 2014 | 09:08 PM
Skirmich's Avatar
Sadly that isn't a replaceable Item only way to get it new is to buy the whole TB..
You can always DIY some temporary fix in any case if it lets go you will only lose Cruise again.
Old Apr 15, 2014 | 12:42 PM
Thanks guys, I did get it to stay in temporarily. Maybe I'll look for a junked TL and try to remove that part from the throttle body.
Anyway, thanks for your help. Once again this site has kept me away from the stealership.
Old Apr 15, 2014 | 01:03 PM
That's definitely your best bet. Little plastic piece like that would run you $5 bucks at a junk yard!
4drviper
Apr 23, 2025 07:13 PM
blacktsxwagon
Oct 27, 2015 10:12 PM
joflewbyu2
Oct 8, 2015 11:16 AM
adreano17
Sep 29, 2015 08:48 AM
Froid
Sep 27, 2015 06:16 PM
