Creaking Noise when Suspension Flexes
Had this problem for awhile, can't figure it out yet.
I know that my cv boot/joint needs to be replaced... or it could be the ball joint.
Anyways whenever my suspension flexes (driveways, dips, bumps, but esp driveways). there is a creaking sound. and its coming from the front right side only.
any ideas?
any ideas?
Check your brake heat shield and make sure it's not touching the rotor. This was happening on mine a couple weeks back and I fixed it by bending the heat shield back. Mine was touching at the bottom of the heat shield. Just shove a screw driver in between and bend it back.
Symptoms: When you press down on the right front fender you hear a creaking sound
Fix: Bend rotor heat shield back...
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
