Crazyness resetting my maint reqd light
Ackniculous One
Ok, so I changed my oil on my 03 Type S the other day and attempted to reset my Maint Reqd light. When you hold down the buttons to reset the light, I got a series of beeps and noticed the numbers on my outside temperature guage started to go up or down. I suppose I may have adjusted my outside temperature. Didn't know it did that. After that, I turned the car off and then held the buttons down, then turned to the "on" position. My maint reqd light went out. But I thought it was weird that I could adjust the outside temp. Any of you all experienced this>?
If you hold the two buttons for several seconds with the car on, it will adjust the correction factor of the outside temperature display. If you hold them down with the car off then turn the key, it will reset the Maintenance Required light. I don't recall, but I believe the temperature correction trick is listed in the owner's manual, too. Kinda neat.
yea we had this discussion a few days ago, im not positive about it being in the manual but i believe it is.
Maint rerd light
Yes, I'm admit I too lazy to read the manual. But again I like to chat with you folks at the forum. Can someone tells me the location of the RESET/SELECT buttons?
mada51589
05-03-2022 08:54 PM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
