crap i put 5w-30 oil in my '03
Old 12-18-2010 | 02:51 PM
pickler's Avatar
so this mornin there was a sale on castrol high milage gtx oils and i bought some and change the oil totally forgot to check oil weight! so i poured in the 5w-30, is this bad for the engine? its got 60k miles on it with 5w-20 oil all its life.
Old 12-18-2010 | 03:08 PM
jjashaa's Avatar
Avant Garde Wheels
still using 5W so it should be fine me thinks.
dsickles's Avatar
you'll be fine
Old 12-18-2010 | 03:10 PM
dudeinaTL's Avatar
You're screwed! Do a 3x3.
Old 12-18-2010 | 04:55 PM
ChucksCL-S's Avatar
No worries.
Old 12-18-2010 | 05:22 PM
fsttyms1's Avatar
the only reason the 02-03 dont use 5w30 any more is for CAFE reasons. 5w30 will be just fine and there is NO reason to be worried.
Old 12-18-2010 | 06:51 PM
01tl4tl's Avatar
like kris said- it was for govt mileage testing bs- which has been changed on how they calculate it~
we can safely run
5-30 normal operation
5-20 normal operation
0-20 extreme cold below freezing all winter
the first number is critical in cold temps
the 30 actually provides more protection against wear since its a little bit thicker
You will find it in many gen2, and even gen3 has wised up to the 20 scam
Old 12-18-2010 | 08:17 PM
ANC297's Avatar
Bonki' Ehrite!
I run 5w-30 every time.
Old 12-18-2010 | 08:47 PM
totaledTL's Avatar
Used 10w-40 for thousands of miles.
Old 12-18-2010 | 10:35 PM
russianDude's Avatar
02-03 has exactly same engine as 01, why would 5w-30 be a problem?
5w-20 is a gimmic to save gas by .00001% or something like that
Old 12-18-2010 | 11:07 PM
pickler's Avatar
arite thanks a bunch for all the answers guys. i also heard that there is less engine wea with 5w-30 dude to higher viscocity. maybe ill stick with it.
Old 12-19-2010 | 10:42 AM
bigeshorte45's Avatar
5w-30 since i've owned the car for three years now...
Old 12-19-2010 | 10:56 AM
01tl4tl's Avatar
the only reason NOT to run 5w30-- would be in the winter and you live in sub freezing temps.
then a good synthetic 0w-20 would help the engine protection on startup,
with its thinner more flowing 0 viscosity- as measured at 32f
I am not aware of a 0w-30 so 20 is good enough for winter
Its all about additives on multi weight oils; to make them work `as if they were the stated viscosity`- but isnt really either one- see internet for info
Old 12-19-2010 | 02:45 PM
pickler's Avatar
really no 5w-30 in winter? i have been running 5w-30 on my other cars over the years in -20c winter no problem.
Old 12-19-2010 | 04:02 PM
what are you guys talking about, my wife's 2008 RDX is Mobil1 5w-30 factory fill. 5w-30 is the best protection for wear for critical components such as turbo and etc.
Old 12-19-2010 | 07:50 PM
fsttyms1's Avatar
5w30 is more than fine in sub freezing temps.
Old 12-19-2010 | 08:17 PM
DaveS221's Avatar
iv heard this as well but not to fully switch to 0-20. but im not tryna get in the middle of an expert debate. i run 5-30 all winter, all summer, all day and night without any problems. methinks if you were doing winter races or sumthing it could be beneficial but just for our plain old acuras 5-30 wrks. fsttyms1 don't you have a ice race car? what kind of oil do you use in it?
Old 12-19-2010 | 08:40 PM
01tl4tl's Avatar
the 5w is good enough to get oil flow to critical parts in a reasonable time in most climates
IF you live where no man should drive when its that cold~ then the extra protection of faster flow of oil from the 0 weight is going to be of help over the years in lessening bearing damage etc
While its a minimal thing for most areas--extreme oil for extreme area!!
Unless you have torn the engine down and inspected every part - you cant say if there is damage or wear
turbo cars have different needs
Old 12-19-2010 | 09:28 PM
DaveS221's Avatar
lol well it seems my engine is ok and that it is not showing signs of blowing up anytime soon
Old 12-19-2010 | 09:29 PM
fsttyms1's Avatar
I run 5w30 in that as well. I probably should run something a little heavier since the car spends most of its run time at or around 7k rpm.
fsttyms1's Avatar
This is where a good Syn helps out. It doesnt turn into sap like consistency like Dino when its cold
Old 12-19-2010 | 09:38 PM
thelastaspec's Avatar
uʍop ǝpısdn ǝdʎʇ uɐɔ ı
I have to drive up a large hill early into my "commute" every morning - 20*+ grade.
Would synthetic offer any positives?
I think synthetic just sounds like its "better".
In reality, I only need change my oil to follow my maintenance light correct?
I've never seen this asked, how is the maintenance light's memory kept? - does it loose its mem when there is no power? or is it hard flashed into the mileage chip?
Old 12-20-2010 | 11:17 AM
01tl4tl's Avatar
synthetic will be flowing and protecting sooner for your uphill battle in the morning
no idea on how it holds the mileage minder, just how to reset it and drive~
its set at 7500 miles to stay on, average oil change as suggested by acura
those in harsh temps hot or cold may want to do sooner
Old 12-20-2010 | 11:30 AM
totaledTL's Avatar
Originally Posted by fsttyms1
...since the car spends most of its run time at or around 7k rpm.
Really-! Most of the time the engine's rpm is around 7000-? Why is that?
Old 12-20-2010 | 01:34 PM
I think because he races it... ?
Old 12-20-2010 | 04:29 PM
gold2003tl (90)'s Avatar
2003 TL-p
have you heard of anyone running mobil one 0w-40 in j series engines?
Old 12-20-2010 | 05:18 PM
01tl4tl's Avatar
his ice racing car runs 7000 rpm, not the street car..it stays below redline...hopefully
(no he doesnt have a normal TL anymore)
Old 12-20-2010 | 06:11 PM
totaledTL's Avatar
OIC....
Old 12-20-2010 | 06:57 PM
01tl4tl's Avatar
his street TL now sports a CL-S engine and 6 speed manual--
thats why I said he keeps it below redline- hopefully..there is no ecu control for overrev protection anymore~
note: fsttyms1 decodes to Fast Times Won
Old 12-20-2010 | 07:04 PM
Never realized that!
Old 12-20-2010 | 09:41 PM
Rockstar21's Avatar
The Dumb One
5w-30 or bust!
Old 12-21-2010 | 12:30 AM
Gfaze's Avatar
S E L L
:shakehead
Keep running 5W30, no need to use thicker oil.
Old 12-21-2010 | 12:44 AM
Aman's Avatar
Your Friendly Canadian
Are there any cons to using a thicker oil?
Old 12-21-2010 | 01:17 AM
Gfaze's Avatar
S E L L
It makes the engine, more specifically the oil pump, work harder to circulate oil. The engine was built to circulate 5w30 through minimal tolerances throughout the motor. When you add thicker oil the amount of lubrication decreases because the oil does not flow into those small crevices as easily as the thinner oil does. At least that's how it was explained to me once, I think.
Old 12-21-2010 | 01:21 AM
Aman's Avatar
Makes sense to me .
Old 01-08-2011 | 05:52 PM
03Atls's Avatar
Is there a specific weight you should use for a lot of highway driving?
Old 01-08-2011 | 06:01 PM
fsttyms1's Avatar
No. Just stick with what the manufacturer recommends.
Old 01-08-2011 | 08:07 PM
01tl4tl's Avatar
consult the owner manual/service book for details on severe ambient temp suggestions
the rest of us run 5w-30 for best engine protection
5w-20 is ok too if thats what you put in last time
Old 01-09-2011 | 05:46 PM
03Atls's Avatar
Thanks for the input.
mada51589
05-03-2022 08:54 PM
bungln
02-20-2019 08:47 PM
Frathora
09-28-2015 11:29 PM
datadr
09-12-2015 09:12 PM
jfman55
09-05-2015 02:55 PM
Quick Reply: crap i put 5w-30 oil in my '03
