Cooling system not working
Hi all, I have a 2003 Acura TL. My car seems to over heat when it sits in park for say 20 minutes. As soon as I start accelerating it starts to cool down.when I checked under hood I realized that both fans aren't working and when I pulled out the small outlet tube that goes from radiator to reserve tank there's no anti freeze come out. Both fuses of condenser and cooling fans are good. The car never over heats while moving only when sitting for awhile. Any ideas where to start/test and how. I did check the thermostat in hot water about two months ago in hot water and was ok. When should both fans kick on? Thank you
You guys are correct, it's a dead fan motor I presume. I hooked up battery power and ground to 2pconnector from Cooling fan motor and it did not work. So I can say that its definitely the cooling fan motor that is the problem correct? Thanks for all the help its been huge....I wouldn't be able to fix my car of it weren't for this site and you guys replying I really appriaaye it
I wish I had a decent junk yard around me, I'm on Long Island and I have small one by me but it sucks... Thanks for the link to rock auto....and yes it's the fan motor... All you do is jumper the 2pconnector coming from motor. B is positive and a is negative for anyone who reads this and needs to check there fan motor.very easy also check fuses and relays.thanks guys
