Consequenses of removing EGR valve?
Old Mar 18, 2003 | 07:24 PM
Will anything go wrong with the car's computer system if the EGR system is taken off the engine?
Old Mar 18, 2003 | 07:35 PM
StanMan's Avatar
probably not, but you might get the check engine light. since it's part of the emissions system, i think it's illegal. why???
Old Mar 19, 2003 | 10:13 AM
hzm82's Avatar
umm yeah....why are you removing your EGR? EGR valve is used to lower NOx emission levels and I'm pretty sure ITS ILLEGAL to remove,even if its not you will get problems with your car. like your engine stopping, knocks, overheating, failing your emission test.
Old Mar 19, 2003 | 10:41 AM
I don't know why you would want to remove it, but it will cause your car to stutter and stall and run rough if you do.
Old Mar 19, 2003 | 07:43 PM
The purpose of an EGR valve is to reroute exhaust gases to the intake manifold at high rpm...So that takes away horsepower and fills up the intake with burnt and dirty exhaust gases which over time can build up to nasty carbon deposits and causes the engine to lose performance and reliability! Some people gain extra horsepower at top end end by removing their EGR valve and it does not cause the engine to run rough..! I dont kno if its illegal here in Massachusetts...but whose gonnna kno?? But i was asking if it would mess up the engines computer system?
Old Mar 19, 2003 | 07:50 PM
fsttyms1's Avatar
correct me if im wrong but the egr valve was/is designed to recirculate exhaust to help burn off unburned fuel gases?
Old Mar 19, 2003 | 07:59 PM
Well from wat ive been told its been designed to please the american government into promoting a pollution free america..lol emissions garbage..thats all i kno that its built for!
Old Mar 19, 2003 | 08:18 PM
lilboykorea's Avatar
my egr is fuking anooying always makes lil anoying noises when im idling...
Old Mar 19, 2003 | 10:01 PM
Allout's Avatar
Blown is Best
I'm not sure on ours but I used to screw an allen head screw into the vacume line that actuates the valve. I wouldn't remove. Since valve never gets opened, no exhaust gas gets pumped in to heat up intake mixture. The down side is that you can carbon up the passage and make it ineffective in case you need to smog motor. Smog checks in CA check operation of EGR valve.
fifer16
1G RL (1996-2004)
Nov 22, 2024 07:07 PM
dainmezron
Oct 16, 2015 06:56 PM
prbori
Sep 27, 2015 01:37 AM
lowgrowl
Sep 26, 2015 05:18 PM
MilanoRedDashR
Sep 24, 2015 11:04 PM
