Computer
Old Apr 19, 2003 | 10:04 AM
kgoessling's Avatar
Computer
I read a post about resetting the computer by disconnecting the negative side of the battery. Does this affect the anti-theft function (is there one) of the radio? Thank you.
Kent
Old Apr 19, 2003 | 10:16 AM
fla-tls's Avatar
On the way!
Yes. If if the battery is disconnected long enough (just a few minutes) you will have to re-enter the security code for the radio.
The code is found on a card that comes with your manual.
Old Apr 19, 2003 | 02:35 PM
kgoessling's Avatar
Thanks for the input fla!!
Kent
Old Apr 19, 2003 | 03:36 PM
doopstr's Avatar
Isn't there a fuse that makes this operation a lot easier?
Old Apr 19, 2003 | 07:12 PM
fla-tls's Avatar
On the way!
I believe you're actually referring to a post from about 2 years ago (ast least that the original post) where it was stated that you could pull fuse 6 on the driver's side panel and press the brake to reset the unit.
It's my belief that this does not reset the unit, and here's why. When you pull the fuse and press the brake pedal, the computer shows that it still contains its calibration for smog tests. Only when you remove power at the battery does this setting go away.
Refer to page 317 of your manual (2002 manual). The way to see if the computer has been reset (as far as these codes go) is to put the key in the ignition, turn it to run, and wait 20 seconds. If the check engine light blinks, the computer's been reset and is not yet smog calibrated. If it simply goes out, it hasn't changed.
(my pleasure, Kent!)
rockyboy
Aug 4, 2024 10:35 AM
Dec 7, 2020 05:39 PM
heykosal
1G RDX DIY & FAQ
Nov 16, 2020 03:59 PM
Jinkazetsukai
Nov 21, 2015 05:28 PM
AcuraKidd
Sep 25, 2015 11:18 PM
