Comptech Spring Load / Rate
Old Apr 16, 2001 | 07:43 PM
eujinc's Avatar
Question Comptech Spring Load / Rate
What's the difference between spring load and spring rate? I just got my Comptech springs and according to the instructions, the springs with the higher rate goes to the left side. Here's the specs for each spring.
Front
Load 1312.7 @ 7.60 In.Ht.
Rate 261.2 Lbs./In.
Load 1309.1 @ 7.60 In.Ht.
Rate 262.3 Lbs./In.
Rear
Load 616.8 @ 9.38 In.Ht.
Rate 193.1 Lbs./In.
Load 638.1 @ 9.38 In.Ht.
Rate 197.8 Lbs./In.
What is the unit of measure for the spring load (eg. in.ht)? The rear springs make sense (load correlates to rate) but the front springs is somewhat opposite. The spring with the higher rate has a lower load than the other spring. Has anyone else noticed this on their springs?
2000 Acura 3.2 TL (Nav) Nighthawk Black Pearl
Old Apr 16, 2001 | 09:28 PM
Exclamation
They're like that - put the springs with the 262 lbs. and 197 lbs. on the left. Mine were like that too - those load rates are not that different from each other - it'll be fine.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
emailnatec
29
Sep 28, 2018 04:27 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
