comptech headers ???
Old May 11, 2003 | 04:50 PM
asiankidd's Avatar
if i dont have the gaskets for these will the factory gaskets work for the apipe that is? if not how can i go about getting a new set?
thanks
JON
Old May 11, 2003 | 05:02 PM
PeterUbers's Avatar
www.comptechusa.com .. get their direct phone line .. and call their parts dept. The o-rings run a couple bucks a piece, the gaskets are a few more dollars. TOtal should be under $25.00 shipped.
Better to go brand new and NOT use the older gaskets. As they heat the FIRST time after you've installed your headers (used i'm assuming) .. they'll form to the shapes of both pieces.
p.s. where did you get your used comptech headers and how much?
CL-S forum??
Old May 13, 2003 | 12:08 AM
chochox's Avatar
is it necessary to have those ct gaskets wen u install new ct headers? i had mine installed and the shop said it should be fine.
Old May 13, 2003 | 12:09 AM
PeterUbers's Avatar
asian kidd ..
can you please update me after you've installed your headers.. I wanna make sure that pre-owned (so to speak) headers work the same as brand new ones .. thanks a lot for your help,
Jul 16, 2017 07:33 AM
BoricuaTL
Apr 8, 2016 01:08 PM
CL-S progression 01
Jan 26, 2016 04:15 PM
k6biv
Sep 22, 2015 02:06 PM
