CompTech Header Quality Concerns.
Old Nov 14, 2000 | 09:01 PM
BNut's Avatar
S/C'd Accord Coming Soon!
Unhappy CompTech Header Quality Concerns.
Did anyone notice things like this when they received there headers? Maybe I'm just being super anal, but it looks like the a lot welds "bled" through the tube. These spots also feel like they are thinner or weaker than the rest of the tube. This same thing is also present where the hanger is welded near the flex joint, but its hard for me to take a picture of that part.
Did everyone else's headers look like this or should I be concerned?
Also, does this 3 to 1 joint look right to you?
Brian =B-)
2000 Accord LX V6 Sedan White - 3,310 lbs w/ driver - 170HP & 160ft/lbs
- Eibach Pro-Kit (1.5" drop)
- Red AEM Short RAM Intake (8-10hp & 5-6 ft/lbs gain on a DynoJet)
- Red AEM Tru Power Pulleys (10hp @ 5,600rpms & 11ft/lbs @ 4,600rpms gain on a DynoJet)
- 15.5 @ 88mph (Track) [with AEM intake] 0-60mph 7.2 sec (G-Tech) [with intake/pulleys]
<FONT COLOR="#800080" SIZE="1" FACE="Verdana, Arial">[This message has been edited by BNut on 11-15-2000 @ ]</font>
Old Nov 14, 2000 | 09:18 PM
JZ39's Avatar
Post
Man--mine did not look like that at all. Everything was smooth all the way around. For a cool grand I would check this out with Comptech--they're really good about customer service. Send them the pics.
2001 Black/Black CL Type S
Comptech springs, headers PIAA 19169 road lamps Solaris 9005 High Beams
http://albums.photopoint.com/j/AlbumIndex?u=1192826&a=8788545
Old Nov 14, 2000 | 10:21 PM
NighthawkBlack's Avatar
Post
I don't have one but common sense says something is wrong!
Old Nov 15, 2000 | 10:26 AM
Guest
Guest
Posts: n/a
Post
On the first pictures, what you are describing as "bleed-thru" is actually proper penetration of the welds. In the last photo showing the inside of the collector, the only thing I can see is that the weld from the outside didn't reach all the way to the bottom of the tube. Since the tubes are so close together at that point when welding from the outside it's very difficult to get down that deep. Look at the weld from the outside and you should see a perfect weld. Will it affect power or durability? No, definitely not. It's just a matter of aesthetics on the inside.
Old Nov 15, 2000 | 12:22 PM
BrightTL's Avatar
Post
When my installer put in my Comptech headers, he said they were the best quality headers he had ever seen. He also said that most aftermarket headers are a bit** to install, but the Comptech went on perfectly.
Just my 2 cents
Old Nov 15, 2000 | 11:23 PM
BNut's Avatar
Thumbs up
Mike,
Thanks for your quick response. Since this is the first header I have seen close up I didn't know if this was "normal" or not. All of the welds are perfectly sealed from the outside part of the header. I'm not a welder so I had no idea if it was normal for a weld to to show up from the inside of the tube.
This post was not meant to scare anyone else from getting the headers but simply to reassure myself that the headers I had are "normal".
Within another month I should have some nice dyno charts for everyone.
Brian =B-)
Old Nov 15, 2000 | 11:44 PM
snook789's Avatar
Post
Its what this place is for, to get answers
Old Nov 19, 2000 | 11:49 PM
Guest
Guest
Posts: n/a
Post
Bright TL,
Did you feel a legitimate difference with your headers installed? I'm trying to convince myself to get a set from Comptech but I've never been in a car with the headers installed. I need to know how much of a performance difference can be felt. And, do you feel the gain in low or high end?
emailnatec
29
Sep 28, 2018 04:27 PM
Jul 16, 2017 07:33 AM
CL-S progression 01
Jan 26, 2016 04:15 PM
SinCityTLX
20
Oct 19, 2015 11:23 AM
