Comptech Exhaust owners
All your base belong to
Does one of your mufflers hang lower than the other?
It seems my passenger side does, and I have seen some photos of other cars that look the same.
Maybe its just the perspective of the exhaust?
I had the same thing with my CT exhaust. I bent the hanger on the exhaust a little to pull it up more and then put the hanger into a different spot on the rubber part (not sure what you would call it). Does that make any sense. I should be putting my car up on a lift to put on my bodykit so I'll take some pics.
Originally Posted by CL Platano
Are these exhaust loud or does it have a tone like a G35?
Comptech is the quietest of all the mufflers. Its most like teh G35 also. nice thing is (like snowman81 said) is you can add teh quiet tip inserts when ever you want and tone it down.
Originally Posted by demolition_x
if your exhaust are hanging a little low get a SS hose clamp and tighten them up. i actually just did mine today. looks alot better. and it cost under 2 bucks
U got any pics of this?
thats what the hanger looks like roughly.
you take the hose clamp around the outside of that. then start screwing it till the exhaust is brought up to where you want it.
this is the clamp you need. i think i got one that was 3 inch and it worked. it was a little big.
Originally Posted by jpadilla
Think of it as your car having nuts ... one of them just has to hang lower.
Originally Posted by big mike 13
i tried the hose clamp... didnt budge my exhaust..
Originally Posted by fsttyms1
Are you sure you did it right? the exhaust should move up (afterall acura did a GREAT job with the hangers and keeping them from swaying and bouncing up and down)
I might put the hose clamps on there just to lessen the movement.
Hey guys,
Sorry to bring the thread back to life... but i'm running into a problem with the CT's as well. In my case though, the right is hanging just fine:
But my left side is so high that it's TOUCHING the rear lip (melted a bit of the paint already
Right now I tucked a thick piece of tissue in between to insulate the heat, but of course that's only a temporary solution. The hose clamp trick seems to be great for raising the mufflers... but for lowering it? Hope you guys can throw me some tips... really appreciate it!
I think that you can move the muffler down a little by hanging it in a different spot on the hanger. I think that rubber piece has a couple different areas where you can wedge the exhaust into so it will be a littl lower. Of course that's not what the other holes are made for but it should work. I haven't looked under there for a while so I don't rememeber exactly but I am pretty sure that should work.
i would loosen the bolts and se if you could slightly reposition the muffler so that it doesnt. If not, i would take the muffler off and bend the hangers on the car down some so that it sits lower
any more suggestions i'd be glad to see them!
Originally Posted by PenancE
fix ur hangars?
Puma Jim
20
Oct 20, 2016 11:59 AM
joflewbyu2
Oct 8, 2015 11:16 AM
k6biv
Sep 10, 2015 06:37 PM
