Comptech Exhaust Issues....
Now that I raised the exhaust up closer to the bumper, it looks soooooooo much better...the only problem I'm noticing now more than before is that the left exhaust tip is sticking out of the bumper while the right side is flush with the bumper...anyone else notice this and came up with a fix? BTW, I used rubber hose clamps to raise the exhaust..
Ed
Ed
![Exclamation](https://acurazine.com/forums/images/icons/icon4.gif)
Be careful with making the exhausts too flush with the bumper. The heat off the exhaust will melt or burn the bumper. BTW I haven't seen anyone with same problems that you're experiencing with the comptech exhausts. It's never going to be perfectly balanced as the left side of the Y-pipe is longer than the right.
I am having that same problem. For what ever reason, since I got the exhaust, the left side has come out further than the right side. It also sags more on the left but my stock mufflers did that as well.
That's why I am not sure if I wanna get the exhaust...
you pay for the sound and look. Now you got the sound, but the look?!?!?!
hum... not to mention that you get unwanted attention from people (cops espcially........)
Re: Comptech Exhaust Issues....
Ed
Ed
Don't get me wrong, The exhaust is more than satisfactory in looks and sound..You can't expect it to fit perfectly, as even the factory exhaust was almost the same thing..The left side hangs a little lower on stock then the right side, but i'm not sure about sticking out more or not... That's something that's not as noticable when it's hanging low..you notice it a lot more when it's closer to the bumper...observe: On factory rubber hangers hanging low....
![](http://albums.photopoint.com/j/View?u=327537&a=2430310&p=47510739&Sequence=0&res=high)
On factory hangers but raised with the radiator hose clamps... its now in the bumper cutout, but about an inch away from the bumper:
![](http://albums.photopoint.com/j/View?u=327537&a=2430310&p=50589647&Sequence=0&res=high)
Ed
Ed
I dunno... I'm still contemplating if I should put on the I N S P I R E in back...
joflewbyu2
10-08-2015 11:16 AM
