Cold Weather - Brakes
Old Jan 14, 2004 | 12:29 PM
RobDDD's Avatar
A couple of times when it has been extremely cold, I have noticed that when I first start the car in the morning and get going that the first time i try to stop i really need to jam the brake pedal down to get the car to stop. After that, everything is fine. Has anyone else noticed this in the cold weather? Is this normal or is there a potential problem? Any thoughts?
Old Jan 14, 2004 | 01:12 PM
Natismati's Avatar
Stop Driving!! your car will eventually blow up!!!
No!!! JUST KIDDING!!!! Just that the break pads are so cold they get stiff..so when the heat up again they are fine!! dont worry about it!!
Sorry if i scared you'!
Old Jan 14, 2004 | 01:14 PM
fsttyms1's Avatar
ive never had that issue
Old Jan 14, 2004 | 01:24 PM
RobDDD's Avatar
Thanks.
Rob
Old Jan 14, 2004 | 02:19 PM
Pure Adrenaline's Avatar
Dragging knees in
That partially explains it. Another reason is the brake fluid in the lines. When your car has been sitting overnight in cold weather, the brake fluid is not up to its operating temperature. It could temporarily clog the brake lines, which requires you to press the pedal really hard, increasing pressure thus clearing up the lines. Just give it a firm push once or twice before you start driving and you'll be fine.
Old Jan 14, 2004 | 02:23 PM
Natismati's Avatar
thats a good explanation too!
Old Jan 14, 2004 | 02:28 PM
Dragging knees in
Oh, yeah. Make sure of the obvious things, like the fluid level, and if there's any leaks.
Jul 16, 2017 07:33 AM
rcs86
Aug 2, 2016 06:52 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
2ManyHobbies
Sep 24, 2015 09:23 PM
